Old 10th October 2007, 03:53 PM   #1
Default My carver hr-752 problem
The right channel on this will cut in and out at times had this in the shop three times now still not fixed. Any ways sometimes it will play fine like now but sometimes it will cut in and out i turn the volume knob up and down it will work fine. when it was in the shop he resodered the pre in and out board and said it worked fine for him. Can it be the volume control or the relays? Any help would be great.
Old 11th October 2007, 06:07 AM   #2
Bigred is offline Bigred  Canada
Anatech is your Carver man here. He most likely will respond when he has the chance. He might have an idea as it might be one of those common faults seen time and again and he says to "look here". Intermittent faults can be a PITA sometimes. I'm gonna assume you have done all the basics and eliminated things like your cables, speaker wires etc. It does sound like a dry/cold solder joint or connection somewhere. Before another trip to the shop maybe try running it without the cover/bottom and when it acts up tap/poke around CAREFULLY and methodically with a nonconductive instrument of some sort.
Old 11th October 2007, 06:45 AM   #3
geminni is offline geminni  Yugoslavia
Try reversing speakers (left to right) and listen if it will happen again and on which side.
Old 18th March 2011, 05:36 PM   #4
untuned is offline untuned  United States
I am having the exact same problem...did you ever get it sorted out? And if so, how?
Thanks,
-GH
Carver m1.0t problem rlaliberty Solid State 3 27th March 2008 06:13 AM
Carver: PM1.5 vs PM 1.5A AltheaToldMe Solid State 1 20th January 2008 11:34 PM
Carver problem bill curtin Solid State 6 9th April 2006 01:48 PM
need help for a carver PM1.5 condos51 Solid State 0 20th January 2006 05:35 PM
Page generated in 0.07621 seconds (70.20% PHP - 29.80% MySQL) with 10 queries
