hi. when i connect my pa-amp to the subwoofer-preout on my main amp, i have to turn the pre-amp output and the input gain on the pa-amp to the max to get enough volume on the subwoofer. so i need a curcuit which increases the signal strength so it matches the pa-amp! (775mV i think)
whats a such curcuit called? can i find something like that on esp's pages? (going to order some stuff from there soon) Øyvind |
#2 |
What tipe of power amplifier is in the subwoofer encl.
Btw. do you have schematic of sub.amp. Re3gards zeoN_Rider |
#3 |
You just want a gainstage. How you do that depends on your preferences and what you have. A simple opamp cct would do.
If the poweramp for your mains is seperate, just pad the signal level down on that to match. Two resistors per channel and 10 mins work. |
#4 |
Two resistors per channel and 8 mins work,thats how I would do.
I think. Regards zeoN_Rider |
#5 |
Speakerholic
Do I hear 6 minutes?
#6 |
PA-amps often need higher level than line level (preamp output). The old school mix boards do this and act as the preamp. Depends on how much you want to spend or how much time to invest. The easy and expensive way is to buy a preamp. The longer, more fun and may be cheaper way is to build a little opamp circuit to act as your preamp. I guess the fast and cheap way might be to get a used mix board, a simple one from DJ or PA systems. It will do the preamp for you.
-SL |
#7 |
i will be using a H\K avr245 as main amp. and TA2400 PA-amp for the subwoofer. im going to build a preamp for it, including 8-band eq, individual phase controll, adjustable lowpassfilter, a rumble filter, and now hopefully a gainstage.
Is a such gainstage complex to build? anyone have design for me? the power amp for my mains are not seperate by btw. |
#8 |
Whatever design you choose will likely have an input and/or output buffer which will most likely be an opamp. Change one or two resistors in the feedback network(s) and you'll be able to set it over a range.
Edit: most will probably have a level control anyway. |
#9 |
an input buffer with +6db to +12db of gain would do. It might be much simpler than that. Can you post a schematic of the amp? It may be possible to change the gain of the amplifier. It might just be one resistor that needs lowering to effect the +6db gain change.
regards Andrew T. |
#10 | |
Like Andrew mentioned in his post an input buffer of +6- +12 db of gain would probably do the job. It is probably a far smarter thing to do than to raise the gain of the amplifier. |
| input sensitivity? | adrianc | Solid State | 17 | 1st April 2008 06:40 AM |
| BJT input dv/dt sensitivity | zilog | Class D | 0 | 18th January 2006 07:31 AM |
| BOZ input sensitivity | gema | Pass Labs | 0 | 29th July 2002 10:55 AM |
| input sensitivity [SoZ] | Phage | Pass Labs | 2 | 21st January 2002 04:07 AM |
| Input Sensitivity | StefanJ83 | Everything Else | 1 | 20th November 2001 10:17 PM |
| Page generated in 0.09331 seconds (87.63% PHP - 12.37% MySQL) with 10 queries |
