leach vs thermal trak output devices
#2 |
You need more than 4 NJL's diodes for an T output stage.
#3 |
Hi Roe,
the standard Leach uses four diodes in the resistor string and I have found it is overcompensated for temperature. The four output devices are ideal for supplying the four compensating diodes, but I fear he will find that bias becomes too low as the sink heats up. It will be very difficult to keep Vre between 15mV and 25mV for all operating conditions. How could we alter the compensation? add a diode in the lower leg? or add a resistor in the emitter side of the Vbe?
regards Andrew T. |
#4 |
Interesting. I see a few curious features here. Not criticizing, just curious:
Is the offset adjustment and regulated front-end necessary for a leach amp? I understood it wasn't really needed. Are 50v decoupling caps enough for the +/-58v front end? Is the input cap a large enough value? I usually see much larger values than this. I'd even use a film cap there if 3-5uF is suitable. ..Todd |
#5 | |
The TC for a NJL diode is 1.66V/C at 2 to 4mA forward current. Output stage of Leach amp has 6 serial Vbe with TC 2 ... 2.1mV/C each. Make the math, please! |
#6 | |
are you saying that the integrated diodes are very different from external diodes? I have measured my Leach clone and 4diodes definitely overcompensates. When Leach changed from three diode compensation he says he did so simplyto bring the diode leads back to the same side of the heatsink so that connecting back the the circuit board was easier. He reckoned three diodes were sufficient. I suspect you have noticed that the diodes are inside the Vbe multiplier loop. Yes triple stage EF has 6BE junctions effectively in series. One of the main advantages of this topology is the very low loading on the earlier stages. The output devices will vary in temperature. Two diode compensating junctions should be about right. The drivers hardly change in temperature. They run at near constant 500mW to 1000mW (depending on Re) irrespective of transient output currents. Partial compensation could be sufficient here. That could probably be met with one more BE drop. The pre-drivers probably vary no more than a few tens of Cdegress from cold start up to high ambient temperature. No compensation is probably required. That senario would probably explain why my 4diode build over compensates.
regards Andrew T. |
#7 |
The best results are achievable when all 6 BE junction are thermally coupled. Then, you have to do the math, if you know TC for all forward biased junctions at working currents.
This is my latest amp with ThermalTrack BJT's on output stage. It has only -5mV drift over Re's from 20 to 70grdC. I have 4 BE series junctions on the output stage, 2 on CFP driver and 2 on output BJTs and 5 NJL diodes used to compensate thermal drift. http://www.diyaudio.com/forums/attac...amp=1191162639 http://www.diyaudio.com/forums/showt...89#post1313489 |
#8 |
The relationship between forward-biased BE junction and internal diode in a ThermalTrack BJT is presented in the following figure
http://www.diyaudio.com/forums/showt...79#post1282579 |
#9 |
The latest Leach amp (4.5) has 3 diodes for biasing. If I will try to build a clone with double pair of thermaltraks and use all 4 diodes I would be very near the same compensation as the original one, am I right?
roender , I know you have tried the thermaltraks from the roender - symasym thread and also your latest project, but if I understand you right you say its not possible to build an amplifier with two pairs using thermaltraks? Please enlight me
Cheers// Ove |
#10 |
Hello
I only founded four NJL0281 and four NJL0302 , so the thermal track Leach's VBE would have less diodes. I'm making my own amp, using a CFP driver output, can a single transistor vas would work good with a CFP driver output ? Here is the cfp drivers output schematic, it's not tweaked but it's near final, is my CFP driver thermal track output are ok ? Thank Bye Gaetan |
| Biasing/thermal compensation of Thermal Trak transistors | Bob Cordell | Solid State | 156 | 11th December 2010 08:38 PM |
| new thermal trak transistors | sss | Solid State | 31 | 27th January 2008 04:40 AM |
| Page generated in 0.11591 seconds (80.71% PHP - 19.29% MySQL) with 11 queries |
