Leach To Thermal Trak
Old 15th June 2011, 03:33 AM   #41
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
Well, here's the beast I put together for a test bed, both bench and listening:
It uses the single Brian Bell-designed Leach amplifier board, laid out for use with plastic-cased output transistors--simplified wiring very neatly compared to TO-3 socket devices. Similar in appearance to a Hafler SE-series small amplifier that I've long admired and the first amplifier I've built that doesn't look industrial-ugly.
A closeup of the NJL1302/3281 Thermal Trak and MJL1302/3281 transistors with current monitor clip leads. Note charge suckout capacitor between the driver emitters for improved high frequency distortion. This may be working better with these high speed transistors than did the MJL21193/4 transistors I installed initially. A 10uF capacitor worked a bit better and seems to reduce high-order distortion products on the oscilloscope display, a result I was hoping for with these devices.
Depending on bias settings, my Fluke digital thermometer reads heat sink temps up to 150F, a lot hotter than I'd prefer to run for other than test purposes.
My Tektronix AA-501A based distortion test set, showing a 1 kHz signal at about 3 watts.
Old 16th June 2011, 02:44 AM   #42
Modifying and testing the Son of Ampzilla that's being repaired (MPQ6002 on order for bias circuit); distortion is very low up to 20 kHz, close to my Tek's residuals of .001%. That's the sort of performance I want to beat in my next amplifier project!
Old 16th June 2011, 05:28 AM   #43
prairiemystic is offline prairiemystic  Canada
Are the ThermalTrak's a single die? Servicing power amps with Japanese O/P transistors with integral diodes (I forgot but I think they were Sankens.
I've seen an output transistor short (collector) to the thermal trak diode, which energizes and destroys more in the diode string. So you can end up with good output transistors but damaged diodes I would run a small fusible resistor or something to limit string current if a fault occurs.
Upcoming July 2011 Silicon Chip Magazine has the Ultra-LD Mk III amplifier and it "addresses the shortcomings of the internal tracking diodes in the ThermalTrak power transistors". Should be an interesting read. They'd used ThermalTrak's in their Ultra-LD Mk II amplifier design and had problems with bias tracking.
Old 6th August 2012, 12:39 AM   #44
owdeo is offline owdeo  Australia
Excellent idea guys - I was about to start a new thread but luckily found this post first. Has anyone actually done any testing on this since?
The two potential problems I see are:
1) The faster, higher gain transistors may cause problems with parasitic oscillation, and
2) The Thermaltrak internal diodes don't have the same temperature characteristics as 1N4004 and may not compensate correctly as used in this design.
It would be nice to know if anyone has actually tested for either of these potential pitfalls. If not, I'll try it myself and post the results, but probably not for a little while.
Old 6th August 2012, 01:08 AM   #45
mlise is offline mlise  United States
I was an FAE for ON and tried out the ThermalTraks in a Harman Kardon Signature 1.3 module. The diode is an ultrafast rectifier die stuck on the same flag as the transistor die, so the thermal coupling is amazing. The original Sig 1.3 amplifiers idled at 100w and had about 0.002% distortion. When I flipped on the modified module, I measured no bias and thought 'Pfft, that diode bias doesn't work', but the distortion analyzer clicked a bit and settled on 0.005% distortion. The module was idling at about 1 watt bias and rock solid. On an amp with good thermal compensation, the bias wanders around a bit (blow on the heat sinks), but in the ThermalTrak the bias on the meter just sits there and stares at you.
The Sig 1.3 has 3 outputs in parallel in a triple darlington, so you get the right number of diodes. I think the emitter resistors might have been 0.33 ohms and I added a few tens of ohms in the diode string. The diodes aren't, strictly speaking, compensating the darlington driver transistors, but the currents are all proportional, so it all tracks.
The original Sig 1.3 has all fancy Japanese transistors, but the module I modified was a prototype that was all blown up, so I just got it going with junk MPSA06/MPSA56 transistors, so you may be able to do much better than the 0.005%. I actually never even bothered to improve it after it came up on the first try. You also won't need the bias adjust pot once you get it going with fixed resistors. That's supposed to be the big deal with ThermalTrak.
Cheers
Old 6th August 2012, 04:44 AM   #46
Hi mlise,
Thanks for sharing your experience. From what I've read, contrary to the Thermaltrak datasheet application notes most OPS configurations really still require some sort of Vbe multiplier arrangement in addition to the Thermaltrak diodes to achieve good quiescent stability - for example Silicon Chip magazine has recently published an updated amplifier design (ULD mkIII) where they have used a Vbe multiplier with the diodes to improve thermal stability since in the original design (mkII) they had relied on the diodes only and many constructors experienced thermal problems. And that design is a simple EF OPS, not a triple. Self and Cordell both go into this in detail in their excellent books also.
My interest is mainly in whether they work well in Leach amp - it already has the combined Vbe multiplier + diodes arrangement so seems like the perfect candidate. However, as mentioned I worry that the faster, higher gain devices will be more prone to parasitics in the triple OPS, and also I gather the forward voltage of the Thermaltrak diodes is lower than the 1N4004s used in the Leach, so perhaps the Vbe mulitiplier coeffiecient will need to be adjusted to compensate. The whole thermal compensation issue seems to be extremely complex if done properly, so being lazy I figured it'd be easier to just try it and see, or better still see if someone else has...
I feel that my Leach amp takes about 15 mins after switch-on from cold to start sounding really good, and my guess is that this is due to higher crossover distortion while the bias is slowly coming up to a stable point as the heatsinks warm up. I'm hoping that improved thermal traking by using the diodes in the Thermaltraks will improve things in this regard.
Cheers
Old 1st July 2013, 09:49 PM   #47
Back to working on my Leach amplifier prototype with ThermalTrak transistors. Of course, there are issues.
Rumors that ONSemi is canceling the ThermalTrak line notwithstanding, I have only two sets of the devices to make a stereo amplifier. So, using another set of 'regular' MJL outputs, I epoxied 1N4004 diodes to the cases above the silicon dies to make a hybrid set for both channels to get things rolling.
On testing the first channel, I immediately found a considerable rise in distortion and bias current with frequency, especially starting at 10kHz. At 20 kHz, the crossover distortion notch is plainly visible unless I considerably increase bias and that leads to a very hot heatsink. 20kHz distortion is almost two orders of magnitude higher than 1 kHz at full power and a couple of times I popped a 5 amp rail fuse (no damage to the amplifier) with audible stress from the power transformer. Rail voltages fall to 50 volts or a little lower.
Obviously, something's not right. I'm going to experiment with base stopper resistors and base to collector snubbers to see if there's oscillation at some extremely high frequency that's not showing on the 'scope.
Distortion at lower frequencies and modest power levels is .007% or thereabouts, though I feel the noise floor is a little high. The circuit board is a unique design by BrianGT, who doesn't seem to be active lately; the other channel will have to be kludged from my main Leach amplifier's 4.5 board with (short) jumpers.
If my new job at Carlisle Interconnects works out, I plan to acquire a bunch of ThermalTrak devices to continue experiments with a full complement of devices and plenty of spares. I'm eager to listen to a working amplifier with these transistors, hopefully taking full advantage of their close thermal tracking and improved linearity and Ft.
Old 2nd July 2013, 12:28 AM   #48
Good to see someone's still working on this.
Are you sure your measurements are abnormal? Leach's THD curve for the amp shows about 0.2% at 10kHz. When I measured mine (built with MJL21193/4 devices) it matched this fairly well - 1kHz THD was about 0.006% but rose to about 0.15% at 10kHz.
I used a thick (5mm) bar of aluminium the width of the board that covers the transistor faces and clamps them evenly to the heatsink. An added bonus of this method is that it allowed me to mount the diodes in the bar, which tracks the device temperatures better and quicker due to its lower thermal mass. Not quite as good as having the diodes in the packages though...
If you read the FAQ section, Leach is careful to point out that the output device fT is not a limiting factor on bandwidth in his design, so don't expect the performance to change much if any. Maybe you are getting parasitic oscillation due to the higher speed devices. The last revision of the design has 10R base stoppers - have you used these?
Old 2nd July 2013, 10:13 AM   #49
R.I.P.
the Leach has two NFB routes.
The Low frequency one is global and includes the output stage.
There is a High frequency NFB that excludes the output stage.
This inherent feature will give a higher high frequency distortion simply because there is little to no feedback around the output stage at higher frequencies.
This leads to an amplifier that is easier to stabilise, but the compromise, in my view, will be higher distortion.
regards Andrew T.
Old 2nd July 2013, 05:53 PM   #50
Bias is thermally stable, but goes up dramatically with frequency; it's definitely different from my other amplifiers. The increase in bias current seems nonlinear, and the reappearance of the crossover notch is very undesirable.
I might try lifting that internal feedback loop to see what happens. I'm not 100% certain that the layout on BrianGT's board is perfect or that I might have gotten a part wrong in building it.
In my initial testing a while back, I used MJL21193/94 devices and I don't recall having problems. The bias diodes were glued to the heatsink, putting them on that metal bar seems like a better idea. As a further experiment, I removed the base stoppers and installed a speedup capacitor on the driver stage, but observed very little difference in distortion for 2 uF, and not much more with 10 uF. I'm going to reinstall the stoppers and take out that capacitor, and see what happens.
Might have already done some of this last weekend, but the current Seattle heat wave has made it too bloody hot in my workroom during the afternoon and evenings.
I haven't tried running IM tests with my Tektronix AA501A analyzer; this test set can run both SMPTE and CCIF tests, but I need to dig into the docs to be sure I'm seeting it up correctly. THD testing is very easy to do, and I monitor the distortion products on an oscilloscope.
Leach To Thermal TrakHide this!Advertise here!
Biasing/thermal compensation of Thermal Trak transistors Bob Cordell Solid State 161 8th March 2014 08:42 AM
new thermal trak transistors sss Solid State 31 27th January 2008 04:40 AM
