Leach To Thermal Trak - Page 2 - diyAudio
Old 26th January 2008, 09:05 AM   #11
Hi Gaet,
the 0r15 is far too low. It will overheat the MJE drivers.
I would still use 4diodes (1 from each output) but you may want to experiment with adding a small resistor value to the emitter of the BD139. Someone symmed this recently and reported good results.
Have you looked at the interview threads - fets includes a section on using diode compensation?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th January 2008, 12:46 PM   #12
roender is offline roender  Romania
roender's Avatar
Hi Gaetan,
With only 4 diodes output stage will be undercompensated and on a verge of runaway:
4*(-1.66) = -6.64 mV/K Total TC for NJL diodes.
4*(-2.1m) = -8.4mV/K Total TC for drivers (CFP) and output BJTs BE junctions.
The output stage will have a total TC = -2.24mV/K !!!!!
You need five NJL diodes with total TC = 8.3mV/K
Mihai
Old 26th January 2008, 12:48 PM   #13
Originally posted by AndrewT
Hi Gaet,
Hello Andrew
I want to keep the drivers allway ON in class A, to minimize switching noise, so what would be the minimum value to replace the 0r15 resistor ?
How about 50 ohm for small resistor value to the emitter of the BD139 ?
You mean to look at the "Bob Cordell Interview: BJT vs. MOSFET" ?
Thank
Gaetan
Old 26th January 2008, 12:51 PM   #14
Originally posted by roender
Hi Gaetan,
Mihai
Hello Mihai
Can I ad a 1N4148 for the fifth diode ?
Thank
Gaetan
Old 26th January 2008, 12:53 PM   #15
roender's Avatar
Originally posted by gaetan8888
watt would be the minimum value to replace the 0r15 resistor ?
Thank
Gaetan
15ohm will bias drivers at 75mA
Old 26th January 2008, 12:57 PM   #16
roender's Avatar
Hello Mihai
Thank
Gaetan
No, use a MUR120. Put all output stage junctions on the same heatsink ... take a look at RMI-FC100 thread. Or use three NJL pairs
Old 26th January 2008, 01:02 PM   #17
Hello Mihai
I have some 1N5819 , can I use that ?
Thank
Gaetan
Old 26th January 2008, 01:06 PM   #18
roender's Avatar
Do not know. If TC=1.66mV/K you could try.
MUR120 is the diode inside NJL transistor.
Old 26th January 2008, 03:27 PM   #19
Or you can use a 4 units endstage and just use the diode on a fifth one.
Reason is you only get 5 Pieces of each as sample from ON Semi
Cheers// Ove
Old 26th January 2008, 04:32 PM   #20
Hello
I should do that, as you guess I did get 5 Pieces of each as sample from ON Semi, at least the fifth NJL will be at good use.
They don't have those NJL at Mouser.com but they have the MJL version only.
Thank
Bye
Gaetan
Biasing/thermal compensation of Thermal Trak transistors Bob Cordell Solid State 161 8th March 2014 08:42 AM
new thermal trak transistors sss Solid State 31 27th January 2008 04:40 AM
Copyright 1999-2017 diyAudio
