Introducing the X-GainClone
Old 9th February 2003, 09:26 AM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Introducing the X-GainClone
I've not tested it, nor build it yet.
It's only an idea I had this morning, and I played with it on simmetrix.
Values aren't critical, and certainly not the best ones.
Gain is 44 (33dB)
Old 9th February 2003, 12:37 PM   #2
Sheriff is offline Sheriff  United Kingdom
Sheriff's Avatar
Hi Bricolo,
Do you have the full version of simetrix, or are you using the demo?? If so how much did you pay for it if you dont mind me asking.
Cheers
Sheriff
Old 9th February 2003, 12:38 PM   #3
Bricolo's Avatar
I use the demo
Old 9th February 2003, 05:06 PM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
I think existing suggestions from Nelson suggests that the X works with a small number if stages only and 3 kind of being the limit. If there are too many stages you would get the "infinite hall of mirrors" effect.
Nothing wrong in testing though. Simple enough to build and if doesn't work then it doesn't work.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 9th February 2003, 07:58 PM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It will work, but it won't be an X circuit. The error of one
half is reproduced with the wrong phase to cancel.
Old 9th February 2003, 08:05 PM   #6
Bricolo's Avatar
Ah! That's why lowering the "crossed resitors"'s values increased the gain
As a correction, I don't see anything else that connecting the "crosses resistors" to the non inverting inputs (that won't be connected to ground anymore, but certainly to a grounded resistor)
Another idea, Mr Pass?
Old 9th February 2003, 10:47 PM   #7
The one and only
My other idea involves using real transistors instead of
girly-man chips.
Old 9th February 2003, 10:53 PM   #8
ststone is offline ststone  United States
ststone's Avatar
I like my chips with vinegar
Thanks for the switches...
Greetings
alleen vragen
Old 9th February 2003, 11:08 PM   #9
Pan is offline Pan  Sweden
Hmm.. I donīt get it, to me it seems like the errors actually will cancel as the chips is in inverted mode... no?
/Peter
Old 10th February 2003, 06:46 AM   #10
Bricolo's Avatar
I hope this is the good one
PS: Nelson:
Introducing the X-GainCloneHide this!Advertise here!
Introducing myself... despotic931 Introductions 3 13th February 2008 03:09 AM
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Introducing Myself C.Jackson Introductions 3 19th April 2006 02:47 AM
Introducing ... Jennifer Introductions 1 27th January 2006 09:13 PM
Introducing myself screwdriver Introductions 1 29th August 2004 12:46 PM
