Old 25th September 2007, 07:56 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default need volume booster schematic
need a schematic for volume booster
not just regular volume one that use an opamp
one that doesnt add distortion
Old 25th September 2007, 11:02 PM   #2
jaycee is offline jaycee  United Kingdom
I'm guessing what you really mean here is that you want a circuit for an audio compressor, as they use on TV commercials to make them sound 5 times louder than the program you're watching!
Old 25th September 2007, 11:52 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi prorms,
Would you please clarify your needs?
An idea of available power supply may come in handy too.
The only thing I understand from your post is that you don't seem to like op amps and that you think they all add distortion.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 26th September 2007, 02:13 AM   #4
i every time i build volume werer need to increase the output
alot of the time i get distortion wondering what would be a good
design to work with
example 25mV to to 8v
Old 26th September 2007, 02:48 AM   #5
anatech's Avatar
Hi prorms,
Alright then, what power supply voltages are available to use? What type of system are you working on?
25 mV is high and 8 V isn't really a signal level. It's higher.
What are you trying to do?
-Chris
Old 26th September 2007, 06:42 PM   #6
+ 7 v
-7 v
i can always change the voltage
Old 26th September 2007, 09:23 PM   #7
you want 8V swings with a 7v supply? no wonder it's distorting - it's probably clipping at around 4-5v.
Old 26th September 2007, 10:09 PM   #8
what would be a good way get out of this problem
Old 26th September 2007, 10:36 PM   #9
More voltage.
Old 28th September 2007, 01:11 AM   #10
what would be a good opamp design to use that will not cause distortion????
also is thier ant way to stop clipping beside increase power supply???
volume control schematic please paulfk Chip Amps 14 18th April 2009 05:25 PM
I need the infrared remote control schematic for motor controlled volume pot noyan Parts 4 24th July 2007 03:05 PM
FM booster MaXiZ Everything Else 2 19th December 2006 06:01 AM
Anybody have a Bass Booster schematic? bryan315 Solid State 12 28th November 2005 08:16 PM
Page generated in 0.09289 seconds (75.84% PHP - 24.16% MySQL) with 11 queries
