Guys,
I have taken note of the F1 popularity. If anyone of you wanted to play with current output amplifier, here is the circuit hint. It is up to you to calculate part values Best, Pavel |
#2 |
Please, instruct us how to control the off set and suggest some values to this schematic. Was one schematic that our forum friend Ostry provided me and i could not control the off set...not exactly this one you suggest..but alike related the topology. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#3 |
And where is the nice paper, with all the explanations?
#4 | |
#5 |
Hi Carlos,
yes, the DC offset depends on sameness of N and P halves. It is not that bad, though, even with change of temperature. In case you disconnect the load, the DC increases substantially. Also, for higher ohm load the DC increases. And gain increases with load, this is a current output amplifier. The DC servo injecting current into input node would be the cure, as Ipanema has mentioned Best, Pavel |
#6 |
You should also move resistors from drain of output transistors to their source to improve linearity.
Regards Robo |
#7 |
No, unless you want the amplifier to blow.
And distortion s HIGHER with resistors moved into sources!! |
#8 |
Hereby something with component values. Iddle current is 1.5A. Transadmitance is about 0.725A output current to 1V input voltage difference (0.725A/V).
#9 |
+ DC offset compensation
#10 | |
diyAudio Moderator Emeritus
| Output transformer current and power ratings | boywonder | Tubes / Valves | 3 | 29th April 2009 09:00 PM |
| Fullrange, are you guys kidding yourselves? | cirrus18 | Full Range | 290 | 30th December 2008 06:07 AM |
| Is this a competitor? | dshoaf | Pass Labs | 13 | 29th May 2005 08:32 PM |
| Page generated in 0.09953 seconds (78.30% PHP - 21.70% MySQL) with 11 queries |
