#11 |
As a kit there is limited quality control because of the workmanship, and thus results are not always predictable. There is also very considerable service backup.
Therefore the business model for kits is on the edge of viability, and so purchase of modules may be the only way to go if you want guaranteed high quality and warranty. Cheers, Hugh |
#12 | |
Have a look at this thread and confirm who told Anthony about the exact phenomena of Cross-Conduction in Mosfet amps and also that his modules were suffering from Cross-conduction at HF N-channel amp. best regards, K a n w a r |
#13 | |
you may have told him but that doesn't mean everything he knows about it came from you.....he could have done some research (and experimenting) of his own.
#14 |
Kanwar,
I am sorry - I did not mean to discount your good advice!! Your circuits have impressed me greatly, Kanwar, you are 1 very smart guy. That mosfet drive circuit is one of the cleverest things I've seen, up there with the NP-PMA concept. However, I could crawl behind semantics and suggest that I have met Anthony - but I have not yet met you!!! Ciao, Hugh |
#15 | ||
I have used the word "TOLD" not "TAUGHT" in my previous post. which states clearly that i just describe Anthony that his modules were suffering from Cross-Conduction at HF....... Quan you are dragging my statement towards wrong path, Stop this blasphemy. Quote:
You misunderstood my pevious post, i have no intention for disrespecting anyone.I hope we shall meet someday and have dinner together. Cheers Major
#16 |
Hello Kanwar
Thank for refering to that link about cross-conduction, I've learn something very usefull about Mosfet amp. http://www.diyaudio.com/forums/showt...189#post685189 Gaetan |
#17 |
#18 |
Hi Guys
It might be useful to point out that the cross conduction issue, was only with one of my very early N-channel designs. which used Hexfets. none of my other Hexfet amplifers or my current lateral MOSFET designs suffer from this problem. |
#19 |
Mmm. The issue of cross conduction or gm doubling has had reasonable press in many forum threads so it's surprising that there's still a rather divided consensus of opinion.
In my playing with complimentary output stages I'm resigned to the fact that it can't be fully eliminated. However, it's my view that the resulting distortions are perhaps easier to deal with than pure crossover distortion, and perhaps even rail induced distortions. One fact that seems to be ignored is that in the real world where a typical wideband musical signal is applied to a class AB amplifier, the large signal LF component serves as continuously varying bias signal for the more critical high frequency end of the spectrum. The implication of this is that the setting of a quiescent bias point is far more important for the reason of cross conduction than it is for crossover distortion. However, let it not be ignored that a VAS with a very low output impedance is not that difficult to design and serves as a good way to eliminate most of the ill effects of cross conduction. IMO, Attempting to reduce cross conduction or crossover distortion with elaborate temperature compensated bias generators is a big waste of time because it's virtually impossible to achieve at high frequencies which is where you really need it. |
#20 | |
Account Disabled
electronics magazine Silicon chip, so i know of him well over a decade, cool!, cheers
| FS: AV400 Anthony Holton Aussie Amps | HipoFutura | Swap Meet | 5 | 14th July 2011 05:56 AM |
| cheap LM3886 amps for aussie | ttan98 | Chip Amps | 9 | 27th March 2008 10:19 AM |
| aussie amps | MEGA-amp | Solid State | 6 | 31st July 2005 02:17 AM |
| Aussie amps...? | mrnedrub | Car Audio | 2 | 18th February 2005 08:15 AM |
| Page generated in 0.12442 seconds (83.42% PHP - 16.58% MySQL) with 11 queries |
