8 Watt - SINGLE END solid state 8 Watt - SINGLE END solid state - diyAudio
Old 8th February 2003, 04:52 AM   #1
halojoy is offline halojoy  Sweden
On Hiatus
Thumbs up 8 Watt - SINGLE END solid state
I seached the web, and came across a very interesting homepage.
It is a private norwegian guy, Nils StrÝm.
He has only 2 projects, but both are very interesting, I think.
Single End 8 Watt Solid State Amplifier,
without global AC feedback.
Also a High End 20 bit DAC, using parallelled PCM1702.
Battery Powered Analog part of the Circuit.
Links:
Nils StrÝm, Norway - Homepage
Single Ended Solid-State Amplifiers
20 bit High End DAC with PCM1702 - pdf
Below is the schematic to the unusual 8 watt SINGLE END solid state amp.
This schematic is also at my FTP-site now.
/halo - Big FAN of Norway!
Old 8th February 2003, 10:01 AM   #2
carlmart is offline carlmart  Brazil
Default Global feedback
Am I delirious or the DC servo is not considered a global AC feedback?
Nothing against it, just curious.
Carlos
Old 8th February 2003, 10:19 AM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
A 100uF cap decouples the AC component in the global feedback signal Vb2, so there should be no audio global feedback.
Old 8th February 2003, 11:22 AM   #4
AKSA is offline AKSA  Australia
Great effort, but horrifically complex for the job it is doing.
Slavish use of CFPs throughout without too much regard for the linearity of the output stage whose driver will have a widely varying current.
Probably sounds OK; CFPs at constant current are reasonably stable. Input stage seems very complex; can't see the point of going beyond a simple diff pair, myself.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
8 Watt - SINGLE END solid stateHide this!Advertise here!
URL collection of Totem Pole and CSPP (Single Ended related) Solid State Output Stage tiefbassuebertr Solid State 7 10th May 2012 05:02 PM
URL collection of Single Ended Solid State Output Stages tiefbassuebertr Solid State 0 27th June 2009 06:53 AM
Single ended solid state amplifiers? fotios Pass Labs 8 11th August 2008 07:29 PM
17 W Single Ended Solid State Power Lars Clausen Solid State 7 27th October 2003 08:46 PM
Copyright ©1999-2017 diyAudio
