Negative Feedback Gain Control
From discussions in other threads:
Why not use the Negative Feedback as a gain control? Normal Feedback value would be full gain. (into the LTP) 0 ohm Feedback value would be 1:1 gain. (someone told me) |
It hard to optimize a design for variable gain down to 1 by changing NFB. In non-inverting config you don't get less than unity gain, so you'd need some attenuation elsewhere. Inverting would get you close to zero but this has the drawback of lower input impedance and gain variation with source impedance.
- Klaus |
That is going in the right direction. Very helpful. . .
2 Attachment(s)
Actually there is a combination of NFB+attunator configuration in non-inverting set-up.
That seems like a viable option. . . .but will it work beyond the opamp?
I think it would be a great option to put on a LTP. The values would be the key. |
2 Attachment(s)
Odd this topic should come up. I've been experimenting with something simular. I am trying varying feedback based on speaker return current. It's a way to compensate for say, a slightly mismatched passive crossover network or some compensation for a speakers resonance. This isnt the quite the same as regular current feedback. It also has another feedback loop which the voltage at the resistor in series with speaker ground adds or reduces feedback. It use the singleton input (single input trans. like the JLH style) and simply connect the negative end of the dc blocking capacitor to the speaker current sensing resistor. Attached is my expermental circuit I've been testing the past few days. This means real circuit built not just simulated. No comments on the amplifier circuit itself please, it will look quite odd and could be rambled about for some time. I am just interested in the feedback concept. Attached in this post is the circuit under test. I will show simulation examples of its behavior in following posts.
2 Attachment(s)
This is the feedback voltage across the speaker current sensing resistor. I used a slightly mismatched passive crossover setup for this example. The basic concept is that this voltage is in phase with the voltage at the VAS collector which is the main feedback point. So the voltage increases the appearant feedback across R9 (the main feedback loop). So with an increase in current through the speaker results in more feedback and the gain reduced. And of course the opposite happens when you get an increase in impendance do to a resonance and the current is reduced. It will remove feedback and try to increase gain.
2 Attachment(s)
And this is the amplifier trying to compensate for the loss of feedback in that 1khz area.
Beyond me. I hope there are some better engineers out there. . . I was just planning to make a 'simple' gain reduction circuit. jerluwoo
has put some serious thought into this. . . looks like a circuit you would find in a amplifier/speaker combo box. . . |
I think it was Cambridge audio that did this on one of their amps. Watch for the pot wiper going open circuit. |
| All times are GMT. The time now is 05:04 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
