Simple shunt reg
Simple shunt reg
Old 18th September 2007, 08:50 PM   #1
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Default Simple shunt reg
Here is a simple shunt regulator with good isolation and low noise. One of the design goals was to use things waiting in the parts bin for too long. Another was low parts count because I plan to use some of those in a phono pre.
Not shown are output/input caps.
There nothing too special about it except it works really well.
One thing I'd like to know is: How can I test/verify for output impedance?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 19th September 2007, 06:31 AM   #2
Werner is offline Werner  Europe
By simulation: attach a 1A current source as load and sweep it over the frequency range of interest. The voltage measured at the output node is 1:1 equivalent to the output impedance.
http://www.tnt-audio.com/clinica/reg...edance4_e.html
ceterum censeo MQAm delendam esse
Old 19th September 2007, 07:03 AM   #3
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Default Re: Simple shunt reg
Rüdiger
Since you are using LT SwCad do this: attach an 1A AC current source I1 at ouput, run AC analize, when card popoup, mark Vout, change Vout to Vout/I(I1) by presing Alt, OK, you will be able to see output impedance vs freq.
Non é mai abbastanza...
Old 19th September 2007, 07:12 AM   #4
Onvinyl's Avatar
Ok, I did.
How do the dB-numbers correlate to Zout? Is it mandatory to get the curve flat?
Rüdiger
Old 19th September 2007, 07:20 AM   #5
plot voltage (or impedance) on a linear scale, not a log/dB scale!
Old 19th September 2007, 07:23 AM   #6
Place a cursor on the Y-axis, press left or right ( I can't remember right now), mark linear scale instead dB.
Impedance shuld be as low as posible and flat as well to 100kHz to 1Mhz region, after that you will see a rise up, play a little bit with a "real" capacitor at output (or without it).
Old 19th September 2007, 07:48 AM   #7
Onvinyl's Avatar
Thanks! yes, I forgot to place an output cap before sim
this is with 100uF and assumed ESR of 0.1R, at the output
Rüdiger
Old 19th September 2007, 09:02 PM   #8
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
right click on the db scale, you can change it to lin or log voltage scale. you can do this with the FFT output as well to easier compute %THD (log is better for that). if you find that your results are "compressed" by using a lin scale, see if you get better results with a log scale. while in the plot scaling window, you can also set the high and low limits of your trace, and you can use this feature to magnify certain portions of the trace (you can also do this by selecting a portion of the output trace by holding down the left mouse button and drawing a box around the portion of interest).
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 19th September 2007, 10:16 PM   #9
sawreyrw is offline sawreyrw  United States
Onvinyl,
How does this circuit work? Where is the voltage reference? If it's dependent to the transistor parameters, I don't think it will be very dependable.
Rick
Old 19th September 2007, 10:59 PM   #10
Onvinyl's Avatar
I'll do my best:
Q2/M1 and R12 form the current source against the shunt reg will work.
The differential fet (2sj109) is the error amplifier. The leds are the voltage reference, held stiff by J3. A portion of the ouput voltage (both DC and AC) is compared to the voltage reference through R2/R6. I made part of R2 a trimpot, so I can vary between 20 - 26 Volts DC.
Q1/Q3 give further gain and provide current. The current through Q3 varies against load changes, so net current through R12 is always the same. In fact, you adjust the amount of the netcurrent through this resistor.
The point to see here is that Q3 shunts current to ground, the less is needed by the load, the more it eats.
Hope that's accurate,
Rüdiger
edit: if a circuit would not depend on transistor parameters, one wouldn't need them, right?
Simple shunt regHide this!Advertise here!
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
Simple opamp/mosfet shunt regulator iko Solid State 64 12th March 2009 06:38 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
