Noise on R-channel NAD C370
Old 18th September 2007, 03:48 PM   #1
sandeman is offline sandeman  United States
Default Noise on R-channel NAD C370
My NAD C370 is producing static-like noise on just the right channel. Id describe it as a random popping sound. The attached scope plot shows the main output of the right channel (1-red) and left channel (2-blue) on a 200 mV/div vertical scale. The amp has the following symptoms:
1. The noise appears in the right channel only and is present at the PRE OUT 1 (R channel).
2. The noise is independent of volume, balance, treble, or bass. Adjusting any of these controls has no effect on the noise.
3. Physically shaking the amplifier does not have an effect on the noise.
4. The noise is present regardless of the input source.
The receiver was purchased in April 2004. I took it to Precision Audio & Video Services in Seattle for repair in Dec 2005. They were unable to determine the problem and suggested sending it to NAD. My wife went into the hospital that spring and the warranty expired before I could send it in.
Im in need of a service and repair manual for a NAD C370 so I can attempt to trace the signal flow. Id appreciate any other suggestions.
Old 18th September 2007, 09:25 PM   #2
Bigred is offline Bigred  Canada
http://www.eserviceinfo.com/download...D%20C-370.html
I have a full SM of the C-372 (the 370's successor) that might help also.
Old 19th September 2007, 03:46 AM   #3
Thanks for jpg. I would be interested in the C372 service manual. I suspect there a number of differences but the signal flow might be similar.
Old 19th September 2007, 04:02 AM   #4
anatech is online now anatech  Canada
anatech's Avatar
Hi sandeman,
Normally noise like that will be found near the input or Vas stages. NAD uses transistors for muting the signal like many others do. Remove the muting transistors to see if the noise goes away. If these are the problem, you must install new ones using the exact transistor number. They are made with higher Vbe breakdown ratings and so are different. A relay could be used but modifications would be required.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 25th July 2008, 04:32 PM   #5
Alek74 is offline Alek74  Poland
I'm new on this forum. I wonder on modification of my NAD C372. Could anyone send me service malual of NAD C372, please ?
Thanks, Alex
Noise on R-channel NAD C370Hide this!Advertise here!
TDA1541 - noise in one channel? phofman Digital Source 6 17th October 2016 11:57 AM
tda 1543 noise in one channel figge77 Digital Line Level 9 29th June 2009 10:48 PM
Right Channel Noise cwoodall Solid State 4 29th June 2006 07:25 PM
Noise in one channel of Ono Netlist Pass Labs 6 6th March 2006 03:19 PM
