Old 18th September 2007, 02:48 PM   #1
Default SU-9070 help ??
Hi folks I'm new here. I have a question about the SU-9070 preamp. First off I have one channel with no output. I'd like to troubleshoot but don't know where to test the unit as I do not have the service manual. Can any one help me out with this? Please?
Thanks,
Bob Brown
Old 19th September 2007, 03:06 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Bob,
What kind of experience do you have?
What test equipment do you have?
I've repaired many things without a manual, only because I've repaired many with a manual.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 19th September 2007, 05:21 AM   #3
Default Re: SU-9070 help ??
The same happened to me! As I remember it were input/output selectors (bad contact). Try to measure (or change) them.
I have original manuals for Technics SU-9070. If you need them I can send you a copy (please, post your e-mail).
Old 2nd February 2008, 01:46 AM   #4
Ok I fixed the outputs and all was well then I left the preamp on overnight and then in the morning the preamps relay started shutting the unit off and on. I've ordered a full set of caps and will replace them all. I've been looking at the transitors and there are a few I can't find. Specifically the differential Amplifier transitors, SVTM57L, SVT47L and the SVIUPA63H1. I will recap the unit then see how that goes but does anyone know what I should do (if anything) with the differential amplifier parts I can't locate?
The reason for thinking of replacing the transistors is due to the heat these babies give off. My board is discolored where the transistors are from the heat and I can feel them getting hot even when the cover is off. This unit may have spent a bunch of it's life couped up in a with little ventilation hence the heat issues. A few caps show signs of age and for sure should be replaced but do I need to worry about the transistors as well?
Thanks in advance,
Bob Brown
Old 7th February 2008, 04:41 PM   #5
anatech's Avatar
Hi Bob,
Wait until your caps are replaced and test again. The solder connections on these may need to be redone. Do remove the old solder first and avoid solder blobs.
-Chris
Re: Technics SU-9070 MazdaBoi Solid State 9 14th February 2006 10:58 PM
Page generated in 0.07314 seconds (74.61% PHP - 25.39% MySQL) with 10 queries
