Old 17th September 2007, 01:10 AM   #1
brett-ballarat's Avatar
Default Anyone heard of SOUND? (SAQ-505)
Hi all,
Just inherited an amplifier - marked as a SOUND SOLIDSTATE STEREO AMPLIFIER.
Model SAQ-505.
I'm still tracing out the circuit - it has 4 * PNP Ge OUTPUT transistors (2SB407)
I believe it to be the same as the SAQ 501 (markings on the main transformer and attached pics)
There are a few trace cuts on the board that make me think it is based on the 501 boards also.
Anyone have any ideas for replacements for the 2SB407? They are all blown short and a nasty whack of DC is curently squatting on the outputs.
Any help appreciated.
<IMAGES OF AMPLIFIER>
My amplifier worked until all the smoke leaked out !
Old 25th December 2010, 10:37 AM   #2
dave39 is offline dave39  Australia
Default SOUND SAQ 505
I know it is 3 years ago but did you ever find any information, I have just acquired a SOUND SAQ 505 amplifier which was connected to a QUAD 33 pre-amplifier. The previous owner pensioned them off because there was a big thump when the amp was switched on which could suggest a similar fault to what you mentioned with a whack of DC on the output.
Dave
Old 25th December 2010, 10:39 PM   #3
Ian Finch's Avatar
Hi Dave
Not many germanium PNP power transistors around now but I notice on a Google search that B&D Enterprises - Electronic Components Distributor have 6 in stock!!! Better get cracking!
BTW, this "Sound" brand may be just a badge job to cover a generic design by a Japanese manufacturer way back in the '60s when brand names were a sensitive issue. The same amp could have had any number of brands applied worldwide. Perhaps the OEM is marked in fine detail somewhere.
regards
Old 19th July 2011, 02:05 PM   #4
Just picked up the same Sound saq 501 amp.
Lot of hum and distorzion with 2V and 8V DC on the speakers terminal.
There is 40V and 27V voltage on the tween electrolytic and -8V and 24V on the other ones.
Does anybody has schematic?
Old 19th July 2011, 03:39 PM   #5
Bone is offline Bone  United Kingdom
2SB407
Vceo - 30v
Vcbo - 30v
Vebo - 10
Ic - 7A Max
hFE @ 1.5v Vce & 1A Ic = 80 approx
Power @ 25 C = 30 watts
Ft - 350KHz
Old 19th July 2011, 04:49 PM   #6
[QUOTE=Bone;2643769]2SB407
Vceo - 30v
Vcbo - 30v
Vebo - 10
Ic - 7A Max
Ft - 350KHz
I think it is not bad at all because it is in the ultrasonic band so the shematics is probably without strong feedback.
There is interstages trafos inside and sounds very good at moments.
Old 19th July 2011, 06:14 PM   #7
Vceo - 30v
Vcbo - 30v
Vebo - 10
Ic - 7A Max
Ft - 350KHz
Old 20th July 2011, 02:02 PM   #8
Works!
Replaced electolytic with -8V DC reading and it works and works damn good.
It is a quick death for fancy branded toys...
Ever heard sth like this? spirus Tubes / Valves 7 15th November 2008 10:37 AM
What's the SIMPLEST 50W or higher Amp Schematic but best sound you've heard ? calico88 Tubes / Valves 6 16th January 2007 01:18 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 02:15 AM
Have you heard of ... Jennifer Music 0 27th January 2006 08:54 PM
Page generated in 0.10866 seconds (81.35% PHP - 18.65% MySQL) with 10 queries
