Being new in this hobby I'm wondering if anyone has done this: Built a line driver with something like an OPA627P and then added a discrete buffer to it, using something like 2SK170 jfets or the like.
Are there any commercial products like this? Seems like it would be a stupid question but I am curious. |
#2 |
LT appnotes 18,21:
http://www.linear.com/designtools/app_notes.jsp Walt Jung's Classic articles, lower half of page for multiloop/buffererd op amps: http://waltjung.org/Classic_Articles.html |
#3 | |
Is this kinda like putting make up on a pig? A discrete jfet buffer output and an op amp gain stage? I was curious as to the practicality of this, I guess it would be better to go all discrete. I have an OPA627P line preamp that I'd like to add a buffer to. I thought about just throwing a simple discrete jfet buffer circuit on it. Would I put the buffer circuit in the feedback loop? |
#4 |
Jung's articles outline the advantages of buffers/high current gain stages inside the feedback loop of good quality audio op amps
normally jfets wouldn't be useful on the output - today's best CFA op amps are probably better than anything a individual diyer can desigh and build out of discretes |
#5 | |
You might get some argument on that. There are alot of diehards out there. CFA? current feedback amplifier? |
#6 |
Hello,
It's been done. OP-Amps can perform quite well. Discreets can be better, *if* one is sufficiently talented in design. But it does take skill. A buffer doesn't necessarily gain much. Op-Amps can drive modest loads. Personally, I prefer an OPA134 OP-Amp.
Just because you can't hear it doesn't mean no one can. |
#7 | |
#8 |
It would seem reasonable to use a good op-amp for gain and then an open-loop buffer to separate the op-amp from the line-driving work. In this way any issues with the line (such as RFI pick-up) do not get applied to the op-amp feedback stage. The buffer acts quite literally as a buffer.
If done this way (i.e. with the buffer outside, and hence not corrected by, the feedback loop) then the buffer must be very linear by basic design. I would recommend that you search the net (and this forum) for 'diamond buffer'. An interesting example is provided by forum member PMA on his site: http://web.telecom.cz/macura/dispre.png (the right hand part of the circuit is the output buffer) Good luck. |
#9 | |
I'm familiar with that type of buffer. One of the criteria for this is that there be no coupling caps in the signal path. I currently have an LME49710 with a BUF634T as a buffer. I have no coupling caps anywhere in the signal path as I don't need them. I think using something like a jfet source follower outside of the feedback loop would need coupling caps. |
#10 | |
Inside the loop..
Regards Åke |
| 12AU7 based preamp hums when output cable is touched! | frickecello | Tubes / Valves | 11 | 29th April 2009 03:11 AM |
| Where can I get a pcb for a discrete GC preamp? | raypalmer | Chip Amps | 2 | 27th January 2009 10:45 AM |
| which discrete preamp ? | sopapo | Solid State | 12 | 13th January 2006 08:11 PM |
| Discrete amp based on LM38-- family internals? | tiltedhalo | Solid State | 1 | 16th November 2005 01:06 AM |
| Question about Discrete Based(Transistor) Amps? | Tom D | Solid State | 9 | 1st September 2003 04:57 PM |
