Electrical Engineers!... i need information..help old Dx, please!
Old 14th September 2007, 10:33 AM   #1
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Electrical Engineers!... i need information..help old Dx, please!
Well friends, i need your help.
Brazil has a lot of “do nothing” things
beeing sold...we use autotransformer (1 single coil) having electronic switching of
relays to control the AC voltage...called AC voltage stabilizers...has coil tapes of
100, 120 and 140 volts ... so... senses the
main voltage and goes compensating the mains voltage fluctuations.... in the reality, our mains do not fluctuate this way.... the sutotransformer introduces losses, and it is compensating, correcting, his own losses to be a coil in seriew with mains voltage...a do nothing.
Now appeared an “insulator”... a simple transformer having two wires secondary to 120 volts and the primary is switchable from 120 to 240 volts.... this intends to produce you output having ground when you home has not ground..artificial ground or something alike... you can invert and not problem...the input use 2 pins plugs and the output uses the standard three pins plug having ground.
I have not ground in my new home..a more old and simple building....because of that a friend gave me that thing..enormous..having a heavy weigth transformer inside the case...you will see images.
This had not power to face my computer and the monitor refuses to work....so.... power is not so big as i was thinking.
I am thinking to use it in series with other transformers to have other voltages..but i have doubts about the power result.
Can you explain me the result of the image provided...the power expected?
Thank you in advance by the kindness to explain me that.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 14th September 2007, 10:37 AM   #2
Transformer inside is huge... enormous type of transformer, traditional construction E plates and I plates trafo.
Secondary over the primary layers.
The size seems to be a 1.2 Kilowatt transformer...very big.
But specified as 300 VA..... and made sense to me when testing.... real power is not big.
Bad design i think...that iron could produce much more than 300 VA.
Here is one image.
regards,
Carlos
Old 14th September 2007, 10:43 AM   #3
Default Well, the unit was made with the purpose to "create" a ground to you
And to protect your computer against main plug invertions...as the wall have two pins and the plug has three...people use to remove the ground and inject those two pins into the wall.
This produces some problems, i imagine, as one of those wall pins is 220 alternated (Live, Phase)...and the other is neutral (Zero, return)
The unit has 2 pins plug into the input and 3 pins into the output.
It could not feed power enougth to my Sempron 3 Megahertz together my power audio amplifier (class D) and my electron tube monitor, the conventional Samsung.
The supply could not keep the voltage stable enougth...had losses of voltage.
So...this "do nothing" thing will not be used into my computer.
I am trying to use it to audio...maybe... and needing informations about the power i will have...watch the sketch i have made showing two transformers and help me, please.
regards,
Carlos
Old 14th September 2007, 10:45 AM   #4
Default Here the specifications.... the main package had 300 VA inform written there
You see.... five amperes fuse..and 115 volts output...that unit should give me more than 500 watts of power...but negative...have not that power.
regards,
Carlos
Old 14th September 2007, 10:46 AM   #5
nikwal is offline nikwal  Sweden
Using switchmode powersupply must be nice in that situation?.. Most computers have already wide input voltage range?..
Hmm seems like my amps would work perfectly there :-D using wide input range vicor switchmodules (But they can be a bit expensive)..
But an answer to your question I have not.. just more questions..
About earth, couldnt you just drive down a long metal rod into the ground and use as earth? hmm ;-) hehe
Old 14th September 2007, 10:50 AM   #6
Default Yes Nikwall... switching supplies are better...but i have that monster to use
I do not want to make it as junk, to use as a feature to block my door against be shutted because of the wind...not as paper weigth too...ahahahahahaha
I can use the copper rod....but.... building rules, laws, agreements already made, do not let us run wires into the front of the building...nor the back, nor the sides.
So...i can have the rod..the ground..but not the connection to reach my appartment.
The electrical system has a small diameter tube to run another wire together the others already into a tigth space.
Well, my dear, this is third world...thing here are bureaucratic, bad constructed and agreements are very complicated.
But thanks, anyway...at least we had a good social meeting.
regards,
Carlos
Old 14th September 2007, 10:58 AM   #7
I just come to think of it.. We use insulation transformers at work on the testbenches for reparing electronics.. It's quite strange, the old transformers from ASEA sweden are big fat azs things rated at almost no power, and there are also small ones made elsewhere that look rediculus rated at too high power to be safe.. I think it has to do with different rules in different countries how to specify when its "safe" hehe
Old 14th September 2007, 11:04 AM   #8
Default As i told you..we have the old tradition to use the "do nothing"
things.... television aerials that do nothing... looking alike a spacecraft and doing nothing.
Almost all population that uses computers....maybe 80 milions, use the AC voltage stabilizer.
Someone create that idea, and others follow...millions using and they do not know why....they just know that others use..then....may be needed... if may be needed, so...let's use it.
Those fooling things are around us...and this one is the biggest do nothing thing.
You see...i am using..ahahahhaha...everybody use...ahahahahha.
regards,
Carlos
Old 14th September 2007, 11:16 AM   #9
Default The autotransformer everybody uses here
Works fine...do not disturb too much, only the annoying click of the relays.
The one i use is a real 700 watts unit.
Of course the computer works fine without that thing, because the supply is a switching one and works better than those things.
Gimmick...do nothing...unobtanium.... but it is very cheap...that unit cost 20 dollares only!
regards,
Carlos
Old 14th September 2007, 11:29 AM   #10
Nordic is offline Nordic  South Africa
Nordic's Avatar
Get a secondhand LCD monitor if you can't find anything else... it uses much less power.....
Electrical Engineers!... i need information..help old Dx, please!Hide this!Advertise here!
Mix engineers not doing their job!! Richard Ellis Multi-Way 35 28th March 2009 03:14 PM
Filters for other than electrical engineers? Drew Eckhardt Everything Else 0 9th January 2007 07:15 AM
Unemployed engineers Fred Dieckmann Everything Else 14 13th May 2003 07:59 PM
