Radio Shack Digital Wireless Audio Link
CAT. NO. 15-1974 I am trying to modify this unit by taking out the wireless receiver and replacing it with line level inputs . . .I've already done this to the Accurian Receiver(great thread in DIY Audio). Unfortunately, by pulling the "wireless" receiver there is not a simple place to plug in. There is a double row socket of 32 each. They are labeled. Some are even labeled L Audio, GND, A Mute, etc. I will upload a picture tomorrow. I tried connecting to the L Audio and GND connection, but no sound. There is DC offset on both channels. . . .so the signal is just not getting past the socket to the Amplifier. The amplifier is a TDA7265 with the -20V on the heat sink. There is a Mute/Standby function on the chip and I think this is what is preventing it from working. Based on the +V supply, the voltage needs to be -6V from that value across pin 5 to get the amp to fire up. Once I figure this out, I think I will be able to get the amp fired up and running. If anyone has had experience with the TDA7265 or this type of modification, I would greatly appreciate it. |
#2 |
Pictures of Interior
#3 |
Closeup of connector
#4 |
I got the system working.
Just needed to hook up to the real ground 'G2' not the one labeled 'G' next to L 'Out' and 'R Out' Should I add an input capacitor to block DC? |
#5 |
UPDATE.
Sounds good (not great), but better than the Accurian™ HomePlug® Digital Audio Receiver/Amplifier from another thread. The Accurain is a multichip amp while this one is a single chip TDA7265 Played for about 5 hours yesterday at moderate volume on a full range speaker. . . |
#6 |
Just pulled it out of the box and fired it up again. . . still sounds
great. . . not as easy to mod as other RS amplifier but sounds better overall. . .quieter. . . |
| Magnetic contact microphone from Radio Shack audio transformer | Dogue | Instruments and Amps | 0 | 11th April 2009 11:39 PM |
| dat-link+ digital audio interface need help | koko | Digital Source | 0 | 10th January 2008 10:07 AM |
| A question about the Radio-Shack (Tandy) 22-175b digital multimeter | gaetan8888 | Equipment & Tools | 1 | 1st December 2007 02:26 PM |
| Audio DIY, kits and electronics for the Ham Radio Shack-India | peterpan73 | Introductions | 1 | 14th February 2004 05:48 PM |
| Wireless Digital Audio System | audio_steve | Digital Source | 4 | 3rd January 2004 01:28 PM |
| Page generated in 0.10395 seconds (75.37% PHP - 24.63% MySQL) with 11 queries |
