Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 9th September 2007, 12:12 PM   #1
longthrow's Avatar
Send a message via MSN to longthrow Send a message via Yahoo to longthrow
Default better amp configuration
hi guys,
i was wondering which power amp scheme is better:
a power amp with twice a rail voltage or a bridged power amp with supply rails half of the other.
help, suggestions are welcome....
H V E Audio
Old 9th September 2007, 12:26 PM   #2
Gordy is offline Gordy
Consider that for a bridged amp to work correctly the two amps must be exactly matched. Also consider the loop through which the current must flow, including the power supply components (because what flows out must flow back...).
If all other factors are equal, I would choose the higher voltage instead of the bridge configuration.
Old 9th September 2007, 12:31 PM   #3
AndrewT is offline AndrewT
the answer "better or worse" depends very much on the SOA capability of the output stage and on the power output level.
I tend towards using +-2vs IF the output stage can meet the SOA demands required of it.
regards Andrew T.
Old 9th September 2007, 12:33 PM   #4
Did it Himself
richie00boy's Avatar
Bridging loads the PSU more nicely and keeps nasty currents out of ground, but it's more complicated.
And yes, there are capacitors in the circuit. One is even employed to form the dreaded bootstrap on the voltage gain stage. Get over it.
-Burning Amplifier #2, Nelson Pass
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 9th September 2007, 12:35 PM   #5
longthrow's Avatar
hi gordy,
yup, all amps are equal, except for the rail supply voltage & amp scheme..
H V E Audio
Old 9th September 2007, 01:18 PM   #6
longthrow's Avatar
same power is to be delivered into the load,same impedance..
also,over all system gain is the same..
H V E Audio
Old 9th September 2007, 01:33 PM   #7
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Consider that for a bridged amp to work correctly the two amps must be exactly matched. [snip]
No, that's no requirement. The system will work flawlessly even if the amps are mismatched several dB's. You may not be able to get the max output level, but quality doesn't sufer.
Jan Didden
/“Never attribute to malice what can be adequately explained by stupidity - anon
Meet me at Linear Audio
Old 9th September 2007, 09:17 PM   #8
djk is offline djk
"two amps must be exactly matched"
The Yamaha B2-X is a bridge amp. One half runs in class A at ±6V, the other in class AB at ±60V.
Audio (formerly Audio Engineering) published a DIY design to bridge a stereo amp with only one external channel. The 'hot' from the external channel became the 'ground' for the stereo amp. This worked fine at lower frequencies where the bass is common to both channels.
Candidates for the Darwin Award should not read this author.
Old 10th September 2007, 06:13 AM   #9
hienrich's Avatar
hi longthrow,
musta bai!!!
well, for a better speaker excurtion control, I would not go for a bridge amp since damping factor is cut to half when you go bridging....
if you have seen car amps that are usually driven in bridge config, subwoofers are going in and out excessively to the extremes because damping factors are so little to control excursion, this also means that
a bridged amp has a higher output impedance compared
to a single one....
of course power is multiplied by approximately 4.
karon pako bai.......busy kaayo kinabuhi...heheheheheh
macweb
"to invent, you need a good imagination and a pile of junk..." - Thomas Alva Edison
Old 10th September 2007, 09:41 AM   #10
longthrow's Avatar
ok ra bay...
with the same power level,lets say 500Wrms into 8ohms,
that would be approx 90v per rail while if we use a bridged amp,rail voltage is cut to half (45v per rail)
considering the conditions (post#1 & 6)
well now,which is better in terms of performance, cost, efficiency, safety......etc..
from my point of view, bridged amp costs more since higher current is required; that would be more filter caps & more output devices....
btw,which is more safe for the power supply block; i'm planning use an smps for this amp..
H V E Audio
Thread Tools
Does anyone know the name of this configuration? wildswan Solid State 0 9th January 2009 12:25 AM
HELP Transformer, its configuration gamberone Parts 7 25th July 2007 10:18 AM
'Best' Configuration for car sub herulach Subwoofers 5 13th May 2006 04:36 PM
Best configuration for this subwoofer and box? ooheadsoo Subwoofers 3 19th March 2004 04:16 PM
odd configuration Patrat Multi-Way 0 4th February 2003 04:46 AM
Page generated in 0.56508899 seconds (27.48% PHP - 72.52% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
