Old 7th September 2007, 11:46 AM   #1
Onvinyl's Avatar
Default Borbely Cascode
Hi, Borbely often uses this cascode: Figure 7 in this document
Some have wondered, which advantage this might have, because you then get the penalty of very low Vds, so one would normally opt for a explictly biased gate.
But is this method not more quieter than any activly biased solution?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 8th September 2007, 01:24 PM   #2
Banned
Hi Onvinyl,
I think Borbely uses that arrangement due to convenient DC biasing, circuit simplicity and predilection for J-FETs.
The way J-FETs can be biased is not just elegant but advantageous, less contaminating, so very explicit to me. Voltages applied to any sensitive gate or base, as of the cascoding device, should be kept clean, free from ripple and noise, as it would be amplified and mixed with the audio signal. It is not that easy to accomplish for bipolars and MOSFETs all the time.
I am a little bit curious to know your opinion: what would be the penalty of very low Vds?
Old 8th September 2007, 01:52 PM   #3
Onvinyl's Avatar
Hi Lumba,
thanks for your reply.
Well, for one part my current sk246 have a to small Vp, so the Vgs in operating conditions was too small to let the cascoded FET work.
And I think, since the Srin of the upper FET is small, but not 0, you need a very small area were a tiny voltage swing can take place.
Third, but that may as well be an advantage, the gate of the upper fet is not silent, but fed with signal from the source of the cascoded FET. But since it's opposite phase to the source of the upper FET, it may apply a kind of local feedback, which might be useful. But anyhow, the cascoding FET ist not in grounded gate mode, strictly speaking.
Rüdiger
Old 8th September 2007, 07:12 PM   #4
KSTR is offline KSTR  Germany
KSTR's Avatar
Hi Rüdiger,
I might miss your point... but I see both stages, 1st and 2nd, as true cascodes, trying to keep Vds of the cascoded FETs constant. The second stage uses a higher Vds which is generated by offsetting the cascoding FET with a zener. Maybe its not actually higher but just acounts for the different threshold voltages of the cascoding FETs.
Actually he uses -- and has to use -- LM336 5V-references in the final circuit, where he cascodes with enhancement mode MOSFETs with positive threshold -- but draws symbols for depletion mode MOSFETs .
To have the cascoded FET running well above the knee Vds voltages one can use a FET (for the cascode-T) with high negative Vgs(th) and/or offset its Vgs(th) .
Nelson Pass has elaborated on cascode modulation, that is, making the Vds not precisly constant but signal dependent to smooth out part of the nonliearity of the transfer function. Ids increases with Vgs but decreases with Vds so that one might find a point where one gets some useful cancelling. That modulation would happen here if the Zeners went to the supplies, not to the sources.
Something similar happens when the Vds is in the region of the knee voltage, which shifts to the right with increasing Vgs. Quite dependent on and very sensitive to actual device characteristics...
- Klaus
Old 8th September 2007, 11:17 PM   #5
This is an interesting design, and almost ideal. Its biggest limitation is selecting the parts to do it right. People seem to have such a problem with just getting ANY complementary parts, that getting the best parts for this circuit might be a real problem.
The two types of jfet cascode biasing are well known. Usually for the first stage, you use a cascode part with low Gm, but high Idss. This allows a small voltage across the input part, that makes it behave better.
In this case, Borbely uses a voltage source with the second stage part, (just like I do in my new Parasound JC-2 preamplifier). This is a more 'linear' approach, but it does involve more parts and their potential noise contribution.
Old 9th September 2007, 02:41 AM   #6
CBS240 is offline CBS240  United States
CBS240's Avatar
I use to hate j-fets back in my ignorance, but I have learned to love them. Wouldn't build an amp without them. In the case of the input cascode device, a lower Gm higher Idss part usually has a greater Vgs @ Id. It is important to keep the Vdg greater than Vgs on the source j-fet feeding it.
I wish j-fets were more popular by large scale manufacturers, and then there might be some real demand to create and make many different types available, especially matched duals.
All the trouble I've ever been in started out as fun......
Old 9th September 2007, 06:12 AM   #7
Banned
Hi Rüdiger and Klaus,
In my view: the nonlinearity of JFETs is mainly caused by high and varying internal capacitances.
Linearization can effectively be made by keeping certain parameters, like Vds and Ids CONSTANT.
Borbely has obviously special liking for JFETs and other FETs, however, the cascoding device should be bipolar, maybe (discretely made) Darlington.
Old 9th September 2007, 06:14 AM   #8
Banned
CBS240,
JFETs are superior for input stages anywhere in audio.
Old 9th September 2007, 06:52 AM   #9
This has been my choice for many years. Based solely on good results and to many other things to try. Can you elaborate?
Regards, Mike.
"We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. " Niels Bohr
Old 9th September 2007, 09:14 AM   #10
Onvinyl's Avatar
Hi Lumba,
do you have an example circuit for a FET - darlington transistor assemble as cascoding Q?
Rüdiger
Borbely ALL-FET DAC I/V stage hollowman Digital Source 34 6th December 2008 03:29 PM
FS Borbely Headphone Amp flocchini Swap Meet 0 19th September 2008 07:15 PM
Has anyone used Erno Borbely EB-201/168 ANALOG GUY Solid State 14 8th February 2006 10:26 AM
Borbely Audio biovizier Solid State 15 20th December 2005 02:02 AM
Aleph amp vs. Borbely All Fet amp Weil Solid State 2 1st February 2002 12:40 PM
Page generated in 0.12396 seconds (81.72% PHP - 18.28% MySQL) with 11 queries
