Old 18th February 2003, 04:43 PM   #71
deepanger's Avatar
Send a message via ICQ to deepanger
well, about the filter capacitance.. ive read achapter in a good
book (its about linear IC circuits) in a chapter dealing with the
powersupplies. that i only need about 1000uF of filter capacitance
and it recommends 2000uF per 1A !!
so am in confusion
anyway ive found a good brand of 50V 10,000uF capacitors ,so
ithink ican put about 30,000uF into each rail so when mesured
ill get about 1.6V ripple at 5A ,ithink its acceptable..
and sure to get the 5A output ill use the pass transistor (2N2955)
and substitute the 2 transformers with a more powerful ones (maybe 10A ratings)..
so anything iforgot before buying the new items?!
((DeepBass = DeepAnger))
Old 18th February 2003, 07:56 PM   #72
traderbam's Avatar
Sounds good. You might want to add a couple of 1W, 1kohm resistors to your shopping list. Put one across each bank of 30mF caps to ensure their energy is drained away safely after the supply has been switched off.
High-voltage bench power supply pmillett Tubes / Valves 20 16th April 2010 01:59 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 07:06 AM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 03:29 PM
bench power supply jethari Parts 1 14th March 2003 05:31 PM
Page generated in 0.07504 seconds (67.91% PHP - 32.09% MySQL) with 11 queries
