Old 30th August 2007, 01:08 PM   #1
arupg is offline arupg  India
Default Please Help!!! Decoupling Zeners
Hi all:
This is related to the schematic of a Quad 606/707/909 amplifier. Each channel amplifier PCB has 3 critical zeners, notably D1, D2 & D12. I was keen to decouple them and someone recommended using Tantalums. Tantalums are in nature noisy so I chose the Blackgate polarized PK compact series cap.
Please click below to see how I connected the cap.
Upon shut-down of the amp, I got a huge low freq & sub low freq vibrations from my speakers & was really scared whether my precious woofers have blown! Lucky they are still alive & kicking.
I used 2.2uF/100V for the D1 Zener while 22uF/50V for the D2 & D12 Zeners.
The amplifier schematic is below for information. (Red circles marked are the 3 Zeners that I tried to decouple).
http://img262.imageshack.us/my.php?i...hematicfp8.jpg
I will appreciate very much if Forumers can be kind enough to advise what and where things went wrong and also what would be the remedy.
Thanks in advance!!
Arup
Old 30th August 2007, 01:40 PM   #2
DRC is offline DRC  United Kingdom
DRC's Avatar
It may be the fact that your caps are holding the lower voltage rails up for a little longer during power down. maybe a diode across the feed resistors (reverse bias during normal operation) would cause them to discharge back into the collapsing power rails.
In any case you should use a dummy load during testing and probably a series resistor (light bulb) in the ac line as well or you may make an expensive mistake !!
Old 30th August 2007, 03:04 PM   #3
Thanks DRC for taking a look and suggesting a way out. I've marked in BLUE what I consider are the feed resistors. Do you feel they are the ones? Please do take a look at the schematic link below:
http://img205.imageshack.us/my.php?i...cmarkedyt9.jpg
Also, if they are the resistors, do I try the diode across the resistor going into the Zener or away from the zener?
Sorry about the questions..... Appreciate your time & patience!
Old 30th August 2007, 03:58 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
May I ask why you do this? Are you have troubles and want to fix it or is it a tweak/improvement?
/Per-Anders (my first name) or P-A as my friends call me
Old 30th August 2007, 04:04 PM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Yes the blue ones are the feeds, the diode should point AWAY from the zener.
Do you relize that the impedance of the caps is MUCH lower than that of the zener so they will not 'do' anything except maybe for a 2Hz tone ?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 30th August 2007, 04:04 PM   #6
AFAIK, zeners produce noise up to extremely high frequencies, so a more appropriate bypass would be a small film cap, say 0.1uF polywhateveralene. Or a ceramic. There will always be LF noise as well, but the values required to get rid of that are huge, and would give you more problems than you've already got. Depending on the location and function of the zener, bypassing may not be appropriate at all.
Old 30th August 2007, 04:05 PM   #7
janneman's Avatar
True. And of course D12 is already decoupled by C15 for hi-freq noise.
A 0.1uF decoupling right at the two opamp supply pins to ground may be worthwhile, but then again this is a quad. While not infallible, they DID know what they were doing.
Jan Didden
Old 30th August 2007, 04:27 PM   #8
Thank you all for your responses.
peranders: The idea of the caps on the zeners were to get rid of the nasty noises inherent with Zeners.
Modders said to use Tantalums but we all know that tantalums too are noisy. Hence, Blackgate polarized was the next choice to me keeping in mind their small size for easy mount on the foil side of the PCB.
janneman: Thanks for pointing out the resistors.
This is already done with a 0.1uF/100V Vishay 1837MKP - Rail to Gnd on the PS of opamp.
Old 30th August 2007, 05:31 PM   #9
jackinnj's Avatar
Ron Mancini of Texas Instruments addressed this topic in an issue of EDN in 2004 --
http://www.edn.com/article/CA454658.html
Bonnie Baker may also have had something insightful to say about this.
Old 30th August 2007, 08:50 PM   #10
janneman's Avatar
[snip]This is already done with a 0.1uF/100V Vishay 1837MKP - Rail to Gnd on the PS of opamp.
In that case, forget about the elcaps - waste of money.
jan Didden
Screen grid zeners; which? Klimon Tubes / Valves 37 10th March 2008 01:52 AM
FS: various transistors, capacitors, zeners etc Stuart Easson Swap Meet 4 30th September 2006 12:37 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Zeners As Rectifiers mrfeedback Solid State 5 28th November 2002 03:33 AM
Page generated in 0.11124 seconds (81.50% PHP - 18.50% MySQL) with 10 queries
