any build this..how sound
Old 29th August 2007, 01:18 PM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default any build this..how sound
schema
audio
Old 29th August 2007, 02:44 PM   #2
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Looks like none's built and doesn't sound at all.
Old 30th August 2007, 03:32 AM   #3
GK is offline GK  Australia
Default Re: any build this..how sound
Originally posted by tadiam
how sound
With the cathode of D2 connected to the emitter of Q2 instead of the base, no frequency compensation and a woefully inadequate VAS load (R9) I'd say likely sound not good.
Glen
Old 30th August 2007, 03:27 PM   #4
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
It's a bit confusing, but I guess it is a classA variant of this principle :
http://www.diyaudio.com/forums/attac...amp=1097786469
The VBE multiplier (Q12) has steady voltage drop. The value will be the same as = VbeQ2+VbeQ4+VdropR22(10ohm). If adjusted properly, it will make a CCS system for R22 (there's always current passing thru R22)
D1+D2 is a limiter, imagine it is not conducting.
Simple but smart principle, makes the output stage never turn off (at least above the paper, never built it)
Old 30th August 2007, 11:21 PM   #5
Default re
good link
thanks all visitors
audio
any build this..how soundHide this!Advertise here!
Sanity check - mad about sound lm3886 stereo amp build KieranC Chip Amps 35 2nd January 2009 04:30 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Pro Sound EV Subwoofer 133 db 1w/1m HOW TO BUILD? jadenlinkletter Subwoofers 6 28th January 2005 08:55 PM
