Old 28th August 2007, 05:46 PM   #1
Default Help understanding a darlington pair
I'm primarily a tube guy, so I need some help sorting this out. I'm getting negative voltage where I believe it should positive and I'm not sure why. I'm getting (-) between R 27, R26, and C16. I believe it should be positive? Am I correct? I suspect that R27 is breaking down allowing the (-) when it shouldn't be. Any thoughts on this?
I've attached a section of the schematic. Thanks.
Old 28th August 2007, 06:14 PM   #2
acid_k2 is offline acid_k2  Italy
why do you believe it should be positive?
consider resistors r26-r27.... at the base of Q1 you should obtain about -11V.... (without considering base current of Q1)
Old 28th August 2007, 08:09 PM   #3
jerluwoo's Avatar
Yes it should be negative voltage there and the point where q1 and q2's collectors and c18 connect should be near 0 volts.
Old 28th August 2007, 11:25 PM   #4
longthrow's Avatar
Send a message via MSN to longthrow Send a message via Yahoo to longthrow
considering the voltage divider resistors alone(r26 & 27), you'll definitely obtain a negative voltage since r27 is much lower than r26..
H V E Audio
Old 28th August 2007, 11:56 PM   #5
Thanks. I discovered a bad joint, and now I can see how it is supposed to work, and it does with neg voltage and nominal voltage at the collectors. (Still not sure if I like these things!)Thanks again for the help.
Darlington Resistor Steve Eddy Solid State 3 7th January 2009 05:34 PM
is darlington pair is unsuitable for audio amplifier? boxedin Solid State 29 13th October 2006 12:00 AM
Darlington pair Tualek53 Parts 9 16th August 2005 07:54 AM
Darlington and Triple darlington lumanauw Solid State 78 1st December 2004 12:57 AM
What is a darlington output exactly? mjarve Solid State 4 18th July 2004 01:28 AM
Page generated in 0.07066 seconds (75.71% PHP - 24.29% MySQL) with 11 queries
