Lm1036 Tone Control
Lm1036 Tone Control
Old 5th February 2003, 09:58 AM   #1
pundip is offline pundip  Australia
pundip's Avatar
Question Lm1036 Tone Control
I am currently in the process of planning my first proper DIY amplifier. I have built a coiuple of single channel prototypes a couple of years back when i was a teenager never had the money to build something proper until now. I am using the lm3886t as my power amp drive. I will require some form of tone/volume control(balance is optional). It must be easy to build on strip board (dont really have pcb ability yet) and needs to reasonably good quality. I have been looking at the LM1036 chip for quite sometime. It offers a simple and complete solution for my needs... I think. First of all has any one tried this setup or any other setup using LM1036. My biggest concern is the signal to noise ratio is80db on 1036 compared to 92db on the 3886. What is the significance of this? I would also be intersted if there are any alternatives.
Old 7th February 2003, 09:30 AM   #2
Dirk is offline Dirk  Belgium
I have used the LM1036, but I was not too happy with the result (OK, I had some grounding problems too). I even have used the predecessors TCA730 and TCA740 (now THAT's a long time ago!).
If you combine a 80dB s/n preamp and a 96dB s/n power amp, you indeed end up with something very close to 80dB s/n :-(
What I would do now (and what I will do for my next project) is skip the tone controls and just use a decent volume pot in front of the power amplifier (the LM3886 in your case, lots of info on this nowadays: gainclones everywhere!)
Regards, Dirk
Old 9th February 2003, 09:49 AM   #3
pundip's Avatar
I agree with you that remoiving tone controls would simplify the design but I require them. Do you know of any other similar chip that is a all in one package with good quality sound that will work with the 3886.
Old 9th February 2003, 03:05 PM   #4
Cradle22 is offline Cradle22  Germany
Cradle22's Avatar
Hi!
Take a look at the circuits described in the new Project 97 of ESP:
http://sound.westhost.com/project97.htm
They do exactly what you want, and performance mainly depens on your choice of the OP Amp (I would recommend Burr Brown, they've even got a good samples program...)
Ciao,
Arndt
A Sacrifice For Freedom
Old 9th February 2003, 09:22 PM   #5
paulb is offline paulb  Canada
Any particular reason you want all in one package? This can actually end up being more difficult. A lot of the all-in-one chips are surface mount, for instance, which would be a problem for me. Also, I would bet that many of them are digitally controlled.
I like the ESP idea. If you get the circuit board it makes for a very simple effort.
Old 10th February 2003, 01:11 PM   #6
pundip's Avatar
The initall attraction was the chip and the layout was well suited for strip board construction also the control pots didnt have to be ganged. Also I have been told that putting carbon resistors in signal path introduces noise and the dc controlled volume seemed a good way to avoid that. The ESP idea seems like a good plan.
What would be the best opamp to drop in instead of the tl amps. Also is using carbon pots a huge issue, can the noise introduced be ignored or is it wroth going for wirewound pots. (I cant seem to find wirewound ganged pots to save my life). Thankyou for your advice I will post pics once the amp comes to life.
Old 10th February 2003, 02:40 PM   #7
tiroth is offline tiroth  United States
Carbon pots will be much less noisy than that tone control IC. If this is a cheap project I am not sure it is worth worrying that much about the pots. They are an easy item to upgrade later.
You could also look at cermet or conductive plastic pots.
Old 10th September 2014, 09:03 PM   #8
vvnaon is offline vvnaon  Mexico
Default Dual DC Operated Tone/Volume/Balance Circuit
Hi there, I share this proyect fixed, fixed because i found in a web page and those work, after this take a look the datashhet and see some errors, well, this is the history enjoy it!
File Type: txt Componentes.txt (582 Bytes, 56 views)
Old 10th September 2014, 11:10 PM   #9
And I forget tell......... THAT'S REALLY WORKS VERY GOOD!!!! the loudness got a great effect in the speakers to much better than TL072 or 4558, to much deep in treble and bass, in fact, don't know why they call "Tone Control"
Old 11th September 2014, 09:49 PM   #10
Some pics, and I use sta540 like amplifier
Lm1036 Tone ControlHide this!Advertise here!
Tone control pre-amp digi01 Chip Amps 16 13th June 2011 07:18 AM
LM1036 for subwoofer volume control? Swap_File Chip Amps 7 5th February 2009 06:50 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
TI's Tone control JhonDoe Chip Amps 26 13th July 2004 01:29 AM
