Old 27th August 2007, 10:09 AM   #1
max29 is offline max29  Netherlands
Default schematics sony Ta- F6B
Need the Power supply schematics of this sony TA F-6B
Any one all help is welcome.
Now the 3.15A fuse is blowing all the time.
Thank you all
Max
Old 27th August 2007, 10:32 AM   #2
destroyer X's Avatar
Default You have to test the power output transistors
And then the drivers... and then continue to the smaller ones.
Supply and power transistors are always in the top of the list when we have burned fuses...there are other causes,but for sure those are the main ones.
You need to desolder 2 of the transistor leads...one can be keept into the printed board and test them.
Check also your power supply rectifiers and observe the condensers if warm, and check if something is dark, burned, smelling bad or something.
I could find the TA-F30...... maybe this can help you...there's a chance that only voltage will be different...maybe also the output transistors different.
May be helpfull to some start of debugging.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 27th August 2007, 11:34 AM   #3
ilimzn is offline ilimzn  Croatia
TA-F6B uses a switching power supply, which makes debugging somewhat of a problem. It also uses proprietary Sony driver chips in the power amp.
You might want to look for schematics for the TA-N86(B) power amp, it uses a similar power supply.
Old 27th August 2007, 05:17 PM   #4
Bigred is offline Bigred  Canada
I'll have to try and dig the schematic out. If I recall it uses CX171 chips.
Old 17th March 2011, 07:06 PM   #5
If you need the schematics for the ta f6b e-mail me.
need a complete amp i have one
Old 17th March 2011, 07:36 PM   #6
zeonrider's Avatar
Default Sony
Here :
Regards zeoN_Rider
Schematics SONY CDP-791 for upgrade CJAVIER Digital Source 4 10th August 2010 09:37 AM
Sony CDP-XA555ES Schematics meraxx Digital Source 1 15th April 2008 02:54 PM
Schematics Sony Ta 4650 max29 Solid State 1 4th October 2007 07:17 PM
Sony Schematics enzedone Solid State 5 12th January 2007 10:22 AM
Sony Amp TA Series Schematics matt09 Digital Source 3 22nd December 2006 09:32 PM
Page generated in 0.08053 seconds (76.76% PHP - 23.24% MySQL) with 11 queries
