PCB layout for audio
Old 28th August 2007, 02:01 AM   #31
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
a useful reference http://www.hottconsultants.com/pdf_f...ixedsignal.pdf
Old 28th August 2007, 02:11 AM   #32
panson_hk's Avatar
Originally posted by ilimzn
Even though we are talking audio frequencies here, some of the things that happen in an amp are way above that band - in particular half-wave rectification in output stages of class AB amps, correction signals for NFB loops, etc. At these frequencies, you need to consider the full current loop, not just the ground line part of it. A ground plane (properly implemented) has the advantage that return paths tend to form a shadow of he outgoing path on the ground plane, hence keeping impedances at a minimum,
I agree with your point.
Old 28th August 2007, 03:56 AM   #33
banana is online now banana  Hong Kong
This is very true.
I've worked with an OEM project, which is a DAC board designed with the ground plane jointed at power supply only (like the Burr-Brown EVM approach). It radiates very badly around 700MHz, clearly the harmonics of I2S MCK. Later I solved the problem by adding wide junction across AGnd/DGnd plane, just underneath the I2S bus.
Old 3rd September 2007, 04:00 PM   #34
h_a is offline h_a  Europe
h_a's Avatar
@panson_hk: thanks a lot for the article! It's a pity that interesting information like this can only be found scarcely!
Anyway, it mainly argues against the isolation of ground planes and recommends physically separated layouting (and a common ground plane in general).
However there's no hint of the usefullness or potential disadvantages of using ground planes per se. Oh dear.
All the best, Hannes
High Octane phono preamp Wiki
Old 3rd September 2007, 10:08 PM   #35
audioDIYer is offline audioDIYer  Europe
You must have some clearance...
PCB layout for audioHide this!Advertise here!
JL Audio Mainboard Layout? XxGoKoUxX Car Audio 9 20th February 2008 03:33 AM
audio buffer layout digi01 Chip Amps 71 7th October 2006 05:34 AM
could John Audio re-desigh the Trace elliot TDA 1514A layout RIC Chip Amps 1 27th December 2003 04:39 PM
PCB layout of audio controller with PGA2310 louischia Pass Labs 20 24th April 2003 11:11 PM
