Can you help me about 2sb649A/2sd669A
Old 25th October 2007, 06:38 PM   #31
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
There are copies, and there are counterfeits. The copies may well be reasonable substitutes for the originals; the counterfeits may be entirely unusable.
I've examined and noted the differences between an original Hitachi B649 and a few possibly copied D669As - the most obvious is the shape of the metal heatsink tab at the back. The front of the copied 669As look similar to the pictures at the beginning of this thread. The original Hitachi always has 3 'rays' around the mounting hole and a very clean-cut outline of the metal tab at the back, the copies occasionally have no rays and the metal tab outline is rough. Incidentally, some of the possible copies came from a sealed pack with the Hitachi logo and the text Taiwan at the bottom - these have 3 rays like the original Hitachi.
The DC beta on most of the probable 669A copies measures around 140-170, which is a tad higher than the tight cluster around 140 or so for the real Hitachi B649. This is probably not conclusive, because of normal NPN/PNP variations, process variations, binning, batches, etc.
However, if the beta is clustered higher than 200, it warrants careful examination. I have one very different-looking D669A outlier with a beta of 360 or so - this has a mounting hole with no 'ray' at all, and a very rough finish on the leads. This is most probably a counterfeit - a small-signal transistor masquerading as a D669A.
Old 25th October 2007, 08:30 PM   #32
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Can you help me about 2sb649A/2sd669AHide this!Advertise here!
2sd669a/2sb669a reddish75 Solid State 9 24th July 2008 04:34 PM
2sb649a 2sd669a drivers jackinnj Swap Meet 0 20th September 2002 02:14 PM
Copyright ©1999-2017 diyAudio
