Can you help me about 2sb649A/2sd669A Can you help me about 2sb649A/2sd669A - Page 2 - diyAudio
Old 22nd August 2007, 01:47 PM   #11
Originally posted by AndrewT
they do a low power To92 version of this transistor with what appear to be identical characteristics.
Hi Lumba,
go and have a look at the Hitachi 2sb647a datasheet.
Most of the data is very close to that for 2sb649, except for the voltage, current and power derating to match the To92 package.
I contend that this same chip could well be used in both devices with just the copper backplate increased to allow the extra dissipation.
But, I could be wrong.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd August 2007, 05:09 PM   #12
ilimzn is offline ilimzn  Croatia
You are probably right, it wouldn't be the first time this was done. just look at the venerable BD139/140 and it's TO92 version, BC639/640.
The chip looks small, but I doubt the real thing is very big, perhaps a bit over 1mm square. The writing is odd, looks like laser cut or etched, the genuine devices are similar but very shallow (almost like print).
Old 23rd August 2007, 08:30 AM   #13
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Hi Andrew,
OK, now I understand what you mean and YES you are very much right. Manufacturers use often transistor chip designs in several different packages resulting in recognizable similarities.
The package of 2SB647 is TO-92L
Other nice devices from Hitachi I would like to mention: 2SD756 2SC1213 2SC1775 2SD1609 and their complementary pairs.
- That`s superior Japanese technology.
Kindly regards
Old 24th August 2007, 06:24 AM   #14
Zeljko is offline Zeljko  Croatia
If this is indeed a high power version, then we would expect the chip to be smaller than the norm, but that does strike me as very small.
Yes you are right, look at attachment, but now I am so confused, is it genuine Hitachi transistor or not
Old 24th August 2007, 06:33 AM   #15
I still cant believe it that small silicon chip can deliver Ic current of 1A .
What is very strange, look how i got it.
Zeljko
Old 24th August 2007, 06:36 AM   #16
And this is one another 2SB649A which looks the same as jackinnjs.
Old 24th August 2007, 06:37 AM   #17
And how it look inside, look at that size of silicon chip!
Old 24th August 2007, 09:27 AM   #18
have you seen Zetec's 3A transistors built into the Eline package?
Some SMDs have similar spec in the sot23 and 223 packages.
It appears that the chips can cope if the heat can get out.
Think about the relative size of a big power transistor and the much bigger heatsink to keep it cool. Same philosophy, but on a different scale.
regards Andrew T.
Old 24th August 2007, 11:06 AM   #19
Banned
Zeljko,
Do not be. UTC is a Taiwanese pirate.
Only Hitachi`s manufacturing technology should be trusted.
Actually 1.5A
The operating area and dissipation level of devices in audio use, in general terms and especially versus data sheets, would be another issue.
Old 24th August 2007, 11:11 AM   #20
Banned
Andrew,
Maybe it can for a while, but I would not like to listen to the sound produced.
Kindly regards
Can you help me about 2sb649A/2sd669AHide this!Advertise here!
2sd669a/2sb669a reddish75 Solid State 9 24th July 2008 03:34 PM
2sb649a 2sd669a drivers jackinnj Swap Meet 0 20th September 2002 01:14 PM
Copyright ©1999-2017 diyAudio
