Transformer problem
Transformer problem
Old 4th February 2003, 02:22 PM   #11
halojoy is offline halojoy  Sweden
On Hiatus
Originally posted by deepanger
itried to draw the wiring but icouldnt get the bridge inputs
neither the ground!
can u complete it if u dont mind?
You need only ONE bridge rectifier.
See UrSv diagram!
halo
Old 4th February 2003, 02:47 PM   #12
Bobken is offline Bobken  United Kingdom
neither the ground!
Much to my regret, I cannot as I cannot do anything other than text with my setup.
However, you are almost there.
Delete the connection betwen the two transformers joining the two secondaries together.
Draw a horizontal line from right to left across the centre of the diagram, halfway between the two transformers and the bridges, and this will be the 'O' volt or ground line.
Make another connection between the two bridges, from the - on the upper bridge, and the + on the lower one. where this line crosses the horizontal ground line, this is also an electrical connection ( the ground).
Add another horizontal line between the lower secondary of the upper TR to the upper bridge, and a similar line between the upper TR secondary and the lower bridge.
This the gives you two AC connections to each bridge, which is what you need and a single '0v' connection from each bridge to ground.
Also as you have shown, the upper bridge has a pos output and now a ground, and the lower bridge has a neg output and now a ground.
I cannot easily describe the orientation of the diodes within in each box representing the bridge, but unless someone else has beaten me to it (please!) I will look on the Forum for a suitable diagram to explain this.
Don't hesitate to come back until everything is absolutely clear as I would hate for you to get it wrong now.
Edit, I see in the meantime the comment that only one bridge is necessary, which agrees with my earlier comments, but as I also said, for a more robust bench PS the two bridge way is better.
Bob
Old 4th February 2003, 03:56 PM   #13
Hi Deepanger,
I see no one else has come up with a diagram as I suggested with two bridges yet, so I have just found the following on the Pass DIY site.
Have a look at : http://www.passdiy.com/images/projects/pearlfig4.gif
This uses two separate bridges, but only one single TR with two secondaries.
If you think of each of the outputs of your two TRs (when they have had their secondaries joined in series to give 24v, as I described before) in place of the two secondaries of the TR shown there (i.e. 30vac), you will have the same arrangement.
Just join the two closest (middle) outputs on that diagram to be grounded for the '0v' line.
This will give the most robust bench supply possible from such an arrangement, and for the cost of the extra bridge, I would go for that.
Otherwise, as I already said, the circuit proposed by UrSv is fine, if a little less versatile if you treat it harshly.
Please post again if you have any further queries.
Bob
Old 4th February 2003, 04:59 PM   #14
subwo1 is offline subwo1  United States
subwo1's Avatar
hi,
This is what Bobken was getting at, i think. This way, you could always connect the two supplies in parallel if you want more current, also.
Old 4th February 2003, 05:07 PM   #15
Hi subwo1,
Thanks a lot, that is exactly what I intended, and as you said, it does also have the additional advantage you mentioned.
For the cost of one extra bridge, it has to be worth it IMO.
It is incredibly frustrating when, like me, one cannot cope with any graphics, and "a picture is worth a thousand words."
Bob
Old 4th February 2003, 05:19 PM   #16
subwo1's Avatar
hi Bobken,
i am not very good with graphics either. i used microsoft paint to save and edit the diagram. That is why it is not neat.
Another advantage of using two bridges is that the ripple frequency is 120hz on each supply instead of 60hz. Then, you may be able to use smaller filter caps.
Old 5th February 2003, 02:22 AM   #17
deepanger is offline deepanger
deepanger's Avatar
Send a message via ICQ to deepanger
Originally posted by subwo1
hi,
Really thanks all for the great replies am getting..
it really enlightened me alot!
one more ques. is if i wanna get more current handling , i should
connect 2 other additional transformers to the existing ones in
parellel ,right?
((DeepBass = DeepAnger))
Old 5th February 2003, 09:00 AM   #18
Yes you can do what you suggest, Also, although you didn't specifically ask about it, you did mention having to wait to get hold of some higher current voltage regulators.
I don't know whether you are also aware of this, but current regs can be paralled too, to cope with higher current demands.
I am reluctant to say that *every* reg can be paralleled like this, but I know of no reason why not in theory, especially if they have inbuilt current limiting and thermal shut-down, both of which features are essential (very highly desirable, from the safety aspect, anyway!) IMHO, for your application.
It is always safer to look at manufacturers data sheets (available on the 'net, usually) for these parameters, as 'applications' advice is often given in this respect, and it may indicate whether paralleling is a good thing or not.
Otherwise, do what I did yesterday when I was looking for a suitable diagram to illustrate the dual transformer/bridge type power supply for you, and do a 'search' on the internet. I found hundreds of different suggested power supplies and arrangements, and it could be you will easily find the information you need from one of these.
Bob
Old 5th February 2003, 05:48 PM   #19
deepanger's Avatar
thanks man so much for ur efforts and help..
about obtaining more current with the lm3x7 igonna seek in this
and reread the datasheets again,
i already found an article that describes something called current
boosting with lm317 regulator using a power transistor, but it
requires about 36,000 or more filter capacitance!! ,, so ican find
it abit hard to implement..
so for now ill draw the design and post it in a new thread, and sure ill need ur gr8 experience in this...
thanks again,,
with regards.
DeepAnger.
Transformer problemHide this!Advertise here!
Transformer problem... 5150ed Chip Amps 19 28th June 2008 02:25 PM
EI transformer in case problem jaycee Solid State 10 1st May 2007 03:43 PM
Serious transformer problem Nixie Power Supplies 50 20th October 2006 11:27 PM
Transformer problem trombone Tubes / Valves 11 15th May 2006 09:33 PM
Transformer problem Semir Power Supplies 3 2nd January 2005 11:36 PM
Copyright ©1999-2017 diyAudio
