Hello my friends,
What do you think about this amplifier and what can be improved? My concern is stability in folded cascode current sources |
#2 |
Q11 and Q13 work in "zener Vbe" ??
#3 |
R21, Q11, Q29 and R22, Q13, Q30 are components of a well known ccs, aka "two BJT CCS".
J3, R1 and J4, R2 are another two current sources used for first two ccs biasing (2sk246 has zero tempco at 0.34mA) That first two BJT ccs form a folded cascode VAS because R11 and R22 currents are modulated by LTP currents. |
#4 | |
Cheers Alex |
#5 |
sorry, my mistake
Thank you, Alex. What do you think about this amp? |
#6 | |
. Also I would not use 2SK170 for the input as these have too much capacitance (IMHO) . My preferred VAS is here:VAS with CD-CB stage In one of the versions I've used a cascoded JFET pair (selected BF244B) on the input (in a similar arrangement to your schematics) with very good results (in Creek A52/A52SE power amplifier). Cheers Alex |
#7 |
95dB OLG it is ok for a moderate NFB design.
As per k170, I like the sound of Toshiba jfets. It is important to have a low capacitance j-fet in a cascoded stage? Thank you, Mihai |
#8 |
Alex,
if input diff pair is FET and it drives a cascode, surely the input capacitance is less of a problem? What's your view on this? I've simulated this type of input circuit on a pre-amp design and get great results. |
#9 | |
Re. JFET - I found in the past that higher capacitance in the input stage is not very good for the sound. However in your circuit you need as high transconductance as possible in a first stage otherwise you will lose the OL gain. Cheers Alex |
#10 | |
It is a one stage amp and as you already had mention, it is nice to have a high transconductance LTP (see how big is the cureent in the front stage ...) Also, a good current mirror in the "VAS" is another trick used to enable high OLG |
| inverting folded cascode ? | promitheus | Solid State | 4 | 2nd October 2007 08:36 PM |
| folded cascode | the_tool | Chip Amps | 1 | 27th June 2006 09:53 PM |
| Symmetrical folded cascode. | Mr Evil | Solid State | 195 | 1st April 2005 03:15 AM |
| folded cascode puzzling | drakonis | Pass Labs | 6 | 30th March 2002 09:04 PM |
| Page generated in 0.09333 seconds (86.13% PHP - 13.87% MySQL) with 11 queries |
