KRELL 484081 and 484002 output transistors remplaces codes. HELP!!! - Page 2 - diyAudio
Old 24th August 2007, 09:13 AM   #11
Originally posted by fepablo
The KRELL is WORKING!!!!!
I replace the 3 x Krell 484081 with 3x MJ15024 and the Krell 484002 with MJ15025. All transistors are from output stage. Krell sells the transistors orginal´s
if the replacements are 15024/5 and they are working correctly then the original 484081/002 cannot be equivalent to 3281/1302. They must be equivalent to some other type.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th August 2007, 10:02 AM   #12
QSerraTico_Tico's Avatar
How long will it work?
Old 26th August 2007, 02:05 PM   #13
Jozua is offline Jozua  South Africa
Default How does it sound?
Hi
Do you detect a sound improvement after the change.
I have a similar amp-KSA200s which I find average sounding compared to other class A amps. I am beginning to wonder if it will sound better if one replaces some of the caps on the PCB with better caps ?
Any comments ?
Jozua
Old 27th August 2007, 03:33 AM   #14
fepablo is offline fepablo  Argentina
Hi guys. The original replaces of 484081/002 are 3281/1302 100% sure, but they are discontinued. The 15003/4, 15015/14, 15024/25, 21193/94 are very similar family of transistors. In the ECA VRT manual, MJ15015 is a direct replace of MJ3281, but i dont use this because he have 180w and the MJ15024 have 250w like the 3281.
The sound is better, i replace transistors of one channel, caps of both and work same the two channels. I have a Martin Logan Sequel II Speakers.
I use the amp few night for many ours without problems or high temp. I attach more pics of the process and my other baby, Marantz 2500.
Old 27th August 2007, 07:19 AM   #15
the 3281 is very different from those others. They are not equivalent.
The gain higher
The gain droop @ high current is lower
The speed is higher
The SOAR varies between types
The power and current ratings are different.
I still think you should have bought a matched set.
I hope this modification works out OK.
regards Andrew T.
Old 29th August 2007, 05:30 PM   #16
K-amps is offline K-amps  United States
K-amps's Avatar
Compared to the 15024/25, Better match would have been 21193/4/5/6, or even 15003/4.
I never liked the highs and mids on the 15024/25 but they had killer bass...
Old 29th August 2007, 05:52 PM   #17
any one else want those half megabit pics removed?
They really slow down the page load on my broadband 500kb limited line.
regards Andrew T.
Old 3rd September 2007, 10:26 AM   #18
Default Caps
Fepablo
I have recently replaced my Krell 100 watter main Sprague caps and the improvement was very impressive. Faster and tighter bass. I got mine from Mouser.
I suggest that you do the same as that amp is about 10 years old and the caps have most likely deteriorated in time.
Jozua
Old 4th September 2007, 05:32 AM   #19
djk is offline djk
djk's Avatar
"MJ15015 is a direct replace of MJ3281"
Totally wrong, just look at the data sheets.
Candidates for the Darwin Award should not read this author.
Old 25th May 2010, 05:33 AM   #20
Hi Friends, finally, 2 years after, i buy the original transistor at Krell.
Thanks Federico.
Transistors for Krell, Spectral,....(VP0120N5 or VN0116N5) moirasc Swap Meet 9 18th January 2016 10:28 PM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 10:14 PM
Transistors for Krell KSA-250? studiotech Solid State 0 4th December 2006 11:43 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Output Transistors weinstro Parts 1 9th May 2003 11:51 AM
Copyright ©1999-2017 diyAudio
