Suddenly Loud Hum in Hafler DH-101 - Page 2 - diyAudio
Old 26th August 2007, 03:30 AM   #11
anatech is offline anatech  Canada
anatech's Avatar
Hi poko,
It's time you sat down with a 'scope and a schematic. Normally the advice you were given will fix your problem. You needed those replaced anyway simply due to age.
Do check that you installed them properly, polarity first.
Take a voltmeter and test all the grounding points. What looks good may not be. You could also measure the ground voltages against your common in the power supply board with the unit running.
Look for blown ground traces. Especially in the input area.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Philips CD303 suddenly no sound! nocount Digital Source 4 2nd October 2009 09:34 PM
Suddenly impressed greenie512 Full Range 15 1st February 2008 11:22 AM
Phono Box Suddenly Not Working chrislacon Analogue Source 1 21st June 2007 01:11 AM
Suddenly, no output from Copland CTA-501 Kevster Tubes / Valves 9 29th October 2005 02:40 AM
sound suddenly faint in old amp - easy to fix? stinkpot Solid State 2 16th May 2005 09:50 PM
Copyright ©1999-2017 diyAudio
