#21 | ||
Hello all!
#22 |
The output stage should hold up even with a shorted downconverter, the outputs are 400V devices and the drivers 200V. As long as there is no signal or the output is unloaded they should be fine. The instant blowup of the output stage suggest shorted drivers or an open bias network.
It probably started with a shorted driver or open (intermittent?) diode string. Then this takes out the outputs, and the drivers. The shorted output stage then causes the downconverter fets to blow, the fuses blow after all the semiconductors as usual... |
#23 | |
Hi Giaime,
I did get your attention, didn't I? Still ..........Hi megajocke, Quote:
The first failure may have toasted the downconverter. For sure, non-matched outputs would cause issues with no emitters to force a balance. The bias circuit may have possibly partially failed also. I would expect it to go short. My guess. An older, powerful sub amp develops broken solder connections. When the amp was moved, flexing of the board caused the failure. The high fault current caused the downconverter to fail short. Hi nick78, Normally I check and resolder connections in sub (and car amps) for this exact reason. It's part of my normal service. It's hard to tell other people what you do without even thinking about it. The beauty of this design, like other Carver amplifiers, is high output power with low dissipation and relative freedom from 2nd order problems. 2nd order issues are reduced, not eliminated with these designs. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#24 |
Of course, if it has a standing current, it will start running away with that voltage as it is not compensated. The OP didn't say if they blew immediately, like power - bang, or after a while (which might not need to be too long). I assumed he meant they blew instantly, which should not happen even with this high voltage.
#25 | |
Hi megajocke,
This is why I suspect an intermittent connection. Next to instant bang if the bias network went open at this voltage. On the Lightstar, the static rest voltage is 13 VDC on the rails. If one got stuck to 125 VDC and the bias network opens briefly, I would expect some damage. -Chris
#26 | |
But since it's not mine to do that with, it's a moot proposal...Todd |
#27 |
The first failure was instantaneous (~ 1/2 second) while moving the sub. I have spoken with NHT and the likely failure is an intermittent connection between the sub's controller and the sub itself (they are connected with a special cable). Basically the two drivers went to max excursion and 1/2 second later the fuse pops.
The 10" drivers are tough birds, I believe they have the same magnet/motor/coil structure of the infamous 1259's. They have shown no apparent damage (measured or observed) from this, and seem to still function perfect. The second failure (when the outputs blew again after I replaced them) was thermal. After being powered on for a minute, the output heated up enough to thermal short and that popped the fuse again after about 1/2 second. I found that, after replacing the blown output once more, that the amp could be turned on for ~ 10 seconds at a time without additional failures occuring, but the outputs on the (+) side would get nice and warm, much warmer than normal I don't know yet if anything further is damaged in the outputs. The speaker output has no significant DC offset, so I don't believe that the (+) side outputs are being driven on to any significant level. My understanding is that the downconverters are designed to keep the voltage drop across the CE junction < 6 volts, a safe bias at 6 volts might be deadly at 130V. fingers crossed. |
#28 | |||
Hi nick78,
-Chris
| Toshiba 2SC3281/2SA1302 - Are these fakes? | kec | Solid State | 65 | 28th May 2011 09:16 PM |
| 2SC3281 2SA1302 Schematic | jleaman | Solid State | 18 | 16th June 2004 06:47 PM |
| Help with possible counterfeit 2SC3281/2SA1302 | trwh | Parts | 6 | 22nd December 2003 05:41 PM |
| 2SA1302 and 2SC3281 | Diode | Solid State | 32 | 15th October 2003 04:05 AM |
| Page generated in 0.12942 seconds (81.07% PHP - 18.93% MySQL) with 10 queries |
