Old 4th August 2007, 07:22 PM   #1
Skorpio is online now Skorpio  Denmark
Default Strange noise...?
I have build a pre-amplifier and it is very quiet, no hum or noise even with my ears close to the speakers.....but...
When I touch the volume control a buzzing sound comes in both speakers....and only when volume is turned up.....not in minimum.....
It is not very loud, but it puzzels me and is a little annoing.....
Old 4th August 2007, 07:24 PM   #2
jaycee is offline jaycee  United Kingdom
This is the 50hz field of power being picked up by your body and injected into the preamps inputs.
Is your case grounded to mains safety ground? If not, you should do this. If it is, you should have your house wiring checked in case you have a bad safety ground connection
Does the input stage of your preamp circuit include filtering?
Old 5th August 2007, 09:21 AM   #3
The baseplate is grounded but the front is not.....
There is no filtering on inputs.....
Old 5th August 2007, 09:56 AM   #4
fotios is offline fotios  Greece
fotios's Avatar
Default Re: Strange noise...?
Have you checked if this noise heared also if you touch any other place on the metal case? Tell me this.
Fotios
Old 5th August 2007, 10:00 AM   #5
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
jaycee;
For your information, we do not have safety earth in our normal wall plugs here in Denmark
Skorpio;
What type of volume pot are you using ?
Have you tried to connect the pot/face plate to PSU Gnd ?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 5th August 2007, 03:59 PM   #6
Originally posted by ACD
jaycee;
Old 5th August 2007, 04:05 PM   #7
Jan Dupont's Avatar
jaycee;
Thats right
Reel men doesn't take back-up or uses safety earth
We have safety earth for household machines like wasing machines, dish washers etc., but not in our standard wall plug for lamps, TV and audio etc....
Old 5th August 2007, 04:07 PM   #8
Jan Dupont's Avatar
However....
Can't count the many times I have been exposed to 230VAC
Maybe thats why my brain works like it does
Old 5th August 2007, 04:10 PM   #9
it's about time we did the humanitarian thing and moved the whole population out of Denmark.
The rules are very different here.
We have to ensure that all exposed conductive parts are connected to safety earth.
If you at least connect all the exposed conductive parts to audio ground then some measure of interference attenuation will accrue.
The metal case around the pot is probably electrically connected to the adjusting knob and to the front panel. Earthing the panel AND the pot case AND the adjusting knob will probably solve the problem.
The pot track and it's three/six terminals should be isolated from the pot casing.
BTW,
how do you make a 220Vac system safe to the user if there is normally no safety earth?
regards Andrew T.
Old 5th August 2007, 04:19 PM   #10
Jan Dupont's Avatar
BTW,
We don't... We are suposed to be wise people, that make our electric connection correct, so no safety earht are needed....
Or maybe it's a way to keep the population growh down
Strange noise coming from MTX Thunder1004 amplifier fastblackcar94 Car Audio 1 17th November 2006 09:17 PM
Quad 405 strange noise post upgrade lance_the_boil Solid State 1 14th October 2006 09:36 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 10:14 PM
Strange noise form lm3875 velikan Chip Amps 2 1st March 2005 04:45 PM
About strange noise from my amp! Otherwise Solid State 6 11th September 2003 12:12 PM
Page generated in 0.12340 seconds (78.23% PHP - 21.77% MySQL) with 10 queries
