Old 2nd August 2007, 06:16 PM   #1
Default Guys....I need help BAD!!!!
I am trying to repair a GE 110w integrated amplifier # 11-4010. I suspect the power amp IC to be the problem. The model of the amp is The power amp IC on the board is a SVI3105 made by Panasonic in 1989. I contacted Panasonic and they were no help. After many hours of searching I cannot find a replacement IC, pinout, or datasheet anywhere on the net. If anyone can provide any information it would be greatly appreciated.
Thank You,
John.
Old 2nd August 2007, 08:30 PM   #2
It is obsolete - a semi custom part.
Chuck it and move on.
Old 3rd August 2007, 12:52 PM   #3
destroyer X's Avatar
Default I had that information..but was erased last year.
Search into Panasonic systems and Technics Receivers.
You will find, very often, the chip SVI3205....but not the one you want.... the SVI3105.
In may imagination...the bottom of memory...the substitution is the RSN3404
Check the pins...the quantity of pins.... i am not sure.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 3rd August 2007, 01:18 PM   #4
Default SVI3105
Hi, try:
http://www.1sourcecomponents.com/partinfo/svi3105.htm
Old 3rd August 2007, 01:57 PM   #5
Cliff,
Thanks for the advise but this is a complete system that was given to me by my mother before she passed away last year. It has tremendous sentimental value and i would like to repair it if possible.
Thanks,
John.
Old 3rd August 2007, 01:57 PM   #6
Thanks for the reply Destroyer X. The SVI 3105 has 18 pins and I think that the SVI 3105 C is a replacement for it but I am not sure. I can't even find a datasheet for it. Oh well, I'll keep searching.
Thanks again,
John.
Old 3rd August 2007, 01:57 PM   #7
Destroyer X, I forgot to mention that the SVI3105 is a 110w x 2 channel power amp.
Thanks,
John.
Old 3rd August 2007, 02:05 PM   #8
Default I have downloaded many Technics and Panasonic...i could not find
And there are many in the search site.
Please, go there and download by yourself...they may ask you registration..but they do not ask payment.
here is the place..... download all Technics and Panasonic...i am sure your chip will be found there, and so you will have schematic and the possibility to tweak, to fix and to substitute.
But you will have a hard work....i have doing that those last hours.
here is the link:
http://fileshare.eshop.bg/service_ma...ets_t_100.html
I wish you good luck.
A good place to enter is this one...here you have in order...from A to Z.... the brand name will be your reference.
http://fileshare.eshop.bg/service_ma...heets_n_0.html
regards,
Carlos
Old 3rd August 2007, 02:18 PM   #9
Default I have tried big John...now your time to make a big try
regards,
Carlos
Old 3rd August 2007, 02:20 PM   #10
Default You may spend a whole day searching...there are many
Those ones i have searched for ya..... they are not using your chip...only the SVI 1302 was found.
There's a big mistake in those big watts dear big john.... that chip will produce 40 watts rms each channel, distorting and screaming as a hunger pig...distorting more than 10 percent to produce that power.
Those Panasonic, and Technics watts are big...very inflated.
regards,
Carlos
Guys Help tresch The Lounge 11 7th May 2009 05:05 PM
Hey, you guys! hairylee Introductions 1 19th November 2004 12:32 PM
Hi Guys! I'm one of the Portuguese Guys who love diy sapito Introductions 3 2nd September 2002 02:19 PM
Page generated in 0.10827 seconds (76.63% PHP - 23.37% MySQL) with 11 queries
