TA-377A Complementary Symmetrical FET Pre Amp
I recently aquired a TA-377A Pre amp.
For those not familiar with the pre amp it consists of a regulated power supply, a line stage and a phone stage. The line stage and phono stage are complementary and symmetrical FET designs.
It sounds like it could be very good and I am presently improving the capacitors to try and make it even better.
However I would like some information if anyone can help.
1) Does anyone know of any articles or threads on this pre amp. I have searched this forum and google but did not find any.
2) the fets are listed as 2n3268 (J40) and 2n3269 (K81). I can not find any specifications for those. Does anyone know these fets?
Any help appreciated.
Don
Hi KaLok
I bought the pre amp second hand. However I believe it originated in HK. Although a company in the US - Mark5 - also sell the pre amp as a kit or ready assembled.
I have been playing with the pre amp some more and now it really is delivering very high quality sound so I am keen to find out more if I can. Are you able to help?
Don
TA 788 PRE
Hi Don
In October 2012 uou posted cct of
TA788 fet preamp
You mentioned that you hawe the transistor numbers and other info of this pre.
I hav built the Pass B1 which is similar.
Recently got a TA 788 which has been messed up.
Need more info to get it live.
Please send me the info if it is not of a neusance to you.
Must do something to kill time this lockdown period.
Thank you.
John.
srian
Not sure I understand your comments.
I said that I would like more information on the pre amp. I also gave the numbers of the fets used in the pre amp. I have no more information but I would like more.
meanie
If you have any information it would be great if you could add it to the thread or send by email which ever is best for you. I would like more info on the pre amp.
Don
TA 788 PRE
Don
I have attached the cct you posted in Oct 2012. According to my imagination,
The input complementaru pairs Q1 Q3 Q5 and Q7 must be 2sk170 bl and 2sj something.
Likewise I do not know the numbers in the other Q numbers as the diagram does not mention these.
So to find currently available replacements it is impossible without these numbers.
I thought you had them when you mentioned you had part numbers.
Thats what I ment.
The numbers are missing in my pcb.
With luck meanie might have these.
  • TA388.pdf
