Old 31st July 2007, 09:24 AM   #1
Question NEED HELP for Pioneer A400x mods
Hi every one, I am new to this forum, I am working on a A400x at the moment.
For the dc coupling I used WAMA 3.3uF MKS4 non-polar. On power supply, i used a high speed rectifier bridge and 0.1uF WAMA bypass on every filter caps. I also added few 100uF/50V Panasonic FC and WAMA MKF on V+/V- of each transistor.
After the mods, rectifier replacement improved the quality of the bass a bit, WAMA give very nice high end, however the whole image became too bright.
Is there anyone have experienced on mods A 400 or A 400x?
Q1: how can I avoid the sound become too bright?
Q2: how can I get better bass control?
Q3: if I increase the bias current, does the 2SA/2SK driving pair needs a heat sink?
Q5: A400 originally 20mA on each power transistors, I am going to boost up to 100mA. Would that give me a warmer sound and better bass control?
Thanks very much!!!!!!!!!!!!!!!!!!
Old 31st July 2007, 11:33 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Did a few small mods on my A400X.
Input caps changed to 4.7uF Nichicon ES and maybe Black Gate N or NX would work well here.
The main power supply caps were changed to 10000uF Nichicon Gold Tune.
Caps for op amp were changed to 100uF Nichicon Fine Gold. Tried a few different op amps such as OPA2134, 5532, AD826 but the original M5220 sounded the best. The other op amps may have needed some different power and by-pass caps but wasn't worth playing with.
The mods have seemed to give a bit more drive all round and more control in the bottom.... deeper may be?? ... a tad more clarity but no other noticeable changes. For the few dollars, was worth it.
Old 1st August 2007, 07:12 AM   #3
zanash is offline zanash  United Kingdom
I suspect your dc decoupling caps are the issue ....try doubling them up to get 6-10uf ...or try a different cap..
I don't have the schems so can't offer any more advice.
Old 1st August 2007, 01:58 PM   #4
Default thanks every one!
Hi, thanks for the replys. here is the link to A400 and A400x manual: http://www.hifiengine.com/manuals_ty...oneer&mod=A400
Old 21st January 2009, 03:57 AM   #5
Hey Rabbitz, where did you source the Nichicon Gold Tune caps in Australia?
Many thanks, Richard.
Old 21st January 2009, 01:02 PM   #6
rabbitz's Avatar
Had to get them from Canada.
http://www.minisemi.com/Nichicon%20M...apacitors.html
No longer DIY active
Old 21st January 2009, 09:41 PM   #7
Thanks for the info
Richard.
Pioneer A400X help. How to uninstall the input switch? Huchiz Solid State 16 21st September 2008 11:33 AM
Pioneer PD-S06 mods - some experience? Alfetta87 Digital Source 0 8th August 2006 01:55 PM
Pioneer PD-65 Schem & Mods richardau Digital Source 14 4th September 2005 04:11 AM
Pioneer DVD-656 Mods kenlow Digital Source 2 14th January 2004 11:41 AM
Sowter/Pioneer AX-10 Mods rljones Digital Source 21 30th December 2002 06:43 AM
Page generated in 0.10545 seconds (73.96% PHP - 26.04% MySQL) with 10 queries
