Hi all,
My friend has offered to build an amplifier for me. Requirements as follows: will be used to drive a set of Monitor Audio (silver) 8i speakers (these are decent speakers and I won't be looking to upgrade them for at least another 5 years. They have 175W written on the back of them, whatever that means) design should be proven and parts available in Australia (or via reputable “mail order” vendor) – can't afford to experiment – need this thing to work and to work well budget: preferably below A$1000 I currently am using an (oldish) Yamaha AX 490. So whatever kit is built should be demonstrably “better”. The Silicon Chip kits seems like an obvious option and of those on offer am considering the 100W ULD and the Studio 350 (preferably the 350 as it seems a particularly quiet amplifier and has extra power). So questions are: Is the 200W for the Studio 350 a concern for my “175W” speakers? How would you rate the performance of these amplifiers compared with commercial equivalents? Is there anything else I should be considering? (Remember i don't want to modify existing designs – unless the mod has been in the public domain for some time and is “proven”) Thanks in advance for any advice/insights. Stuart |
#2 |
I can't find any info on the "100W ULD" kit you mention.. but i'd consider the AKSA 100 amplifier.
Amplifiers built for power can often compromise sound quality in favour of output power. I'd stick with something in the range of 70-100W. The 200W output on your 175W speakers isn't immediately dangerous unless you were to crank it. |
#3 |
Here are the Silicon Chip links for the 2 amps I mentioned:
http://www.siliconchip.com.au/cms/A_100503/article.html http://www.siliconchip.com.au/cms/A_102474/article.html From what I can figure out, these both have similar levels of (quite low) distortion, but the 200W amp has better S/N figure. |
#4 |
Don't get hung up on the numbers.
I'd take a look at the AKSA and which model depends on how far you crank it. You'd still have to figure in a pre amp as well. |
#5 |
The Aksa choice is something alike to give a shot into a 400 meters distant target and find 100 points! Very lucky your choice...going directly to Paradise .... a non stop voyage. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#6 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
Did it Himself
Also have a loot at Rod Elliott's site sound.au.com. Not kits but good designs and a fellow Aussie. Good support as well.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 |
Hi, A 100W into 8 ohm, near 200W into 4 ohm amplifier is a good match. But ~ double or ~ half that is perfectly usable. I might reccomend the ASKA's if I could find any current info on them, I cannot. TBH building an amplifier has many pitfalls for the unwary, you can buy a pretty good amplifier simply for all the parts as its cheaper than buying all the hardware seperately. I'm not up to date with kits available, I'll just note there is more to amplifier design than meets the eye, such as reliability issues, the "sound quality" of a built amplifier is a very moot point, as it will depend on the way its built as much as the intrinsic design. /sreten.
#9 |
#10 |
There is a very good choice of high quality kit amps in Australia. I have made my fair share of amplifier kits and to be honest would steer clear of the Silicon Chip kits because there are others that are so much better. The Silicon Chip amps are designed by engineers who don't seem to be able to listen critically to their creations. They are also designed to a budget, using parts available from Jaycar or Dick Smith. If you want quality go for AKSA (see above for the link), Greg Ball's SKA, or one of Anthony Holton's kits.
http://www.ska-audio.com http://www.poweramplifiers.com.au/ Myself, I am currently building Greg Ball's GB300D and have been impressed with the quality of the kit, far far better than anything ever produced by the magazines. Greg has been very helpful with suggestions to optimise the amp to my requirements. He also has a forum with a lot of interesting and useful information. I don't have personal experience with Hugh's or Anthony's kits, but would not hesitate to order kits from. If only I had more time and $$s I would build amps from all 3 designers! Now that would be fun. Peter |
| Seeking Career Advice | musgofasa | Everything Else | 9 | 8th January 2009 07:29 AM |
| Need advice reagaring speakers/amplifier build. | cerupcat | Full Range | 0 | 12th November 2007 01:48 AM |
| Help, serious newbie seeking advice!! | redmagicsnake | Solid State | 1 | 21st November 2005 03:41 PM |
| Seeking Zen V7R/T and XBOSOZ advice. | chemania | Pass Labs | 3 | 20th January 2005 06:43 AM |
| Seeking advice for my TT project | Dumbass | Analogue Source | 1 | 7th September 2003 07:31 PM |
| Page generated in 0.12525 seconds (80.93% PHP - 19.07% MySQL) with 10 queries |
