Old 29th July 2007, 01:07 PM   #1
timH is offline timH  United Kingdom
Default Negative Sziklai
Can someone give me the layout of a negative sziklai please. I can only find a positive layout
Tim
Old 29th July 2007, 01:23 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Mmm... are you talking about this?
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm
Scroll down. The first schematic has a complete CFP output stage
Old 29th July 2007, 01:38 PM   #3
fig 1a and fig 13 C show your Sziklai outputs and the other configurations.
For anyone else listening, the Doug Self articles are excellent grounding for learners to the subject of discrete amplifier design.
I'm not suggesting copying whole schematics, but more keeping all those little ideas for when they might be needed, eg, 5.7 distortion 7, where to tap off the NFB loop, this mistake is repeated by the majority of experienced builders but should never be made by a competent designer/builder.
regards Andrew T.
Old 29th July 2007, 01:47 PM   #4
Thanks - yes that's what I needed
Tim
Old 29th July 2007, 01:59 PM   #5
Giaime's Avatar
A must read
I perfectly agree. If you could see those errors made in $$$$ priced amps...
Old 29th July 2007, 04:11 PM   #6
I'm actually wanting to use the Sziklai in a VBE (or gyrator or whatever it's called)
This is the circuit I've come up with for a negative version (based on the positive circuit given by teddy-pardo over on pfm) - sorry its a bit larger than necessary
Tim
Old 29th July 2007, 05:21 PM   #7
Giaime's Avatar
Mmm, I think you missed out a resistor. Look at the CFP/Szilaki pair: there is a common collector driver transistor, which has a "current sensing" resistor on its collector, to drive the "bootstrap" power transistor.
So try a resistor between the lower transistor collector, and the upper transistor emitter, of 100ohm - 470ohm, you'll enhance the "cleanup" action of the gyrator.
Edit: Ps depending on the actual transistors, and the spectral content of noise to be removed, you may not need the resistor in series with the lower bjt's base.
Old 30th July 2007, 05:09 PM   #8
Banned
Giaime bouna sera,
no, your explanation is not quite correct. That "current sensing" resistor is actually current source for the PNP transistor. In this application, a series pass regulator, it can be omitted to avoid the injection of harmful ripple voltages into the sensitive base of the NPN transistor.
In other applications it is used for defined higher standing current.
Old 30th July 2007, 05:52 PM   #9
jcx is offline jcx  United States
Originally posted by Lumba Ogir
Giaime bouna sera,
some value of npn_be resistor is usually better than none, increased bias current in the pnp increases gain of the pnp and the R_be can speed up turn off of the npn - both improving input ripple rejection at dc and higher frequencies - the signifcance of both effects varies with transistor properties and operating conditions
Old 30th July 2007, 06:40 PM   #10
Thanks guys - I'm getting outside my understanding envelope with this so I'm gonna go the experimental route and try it without the base to emitter resistor first and then try it with and see if my ears hear a difference
Tim
ps problem is that they're gonna be fitted in a locally regulated pre-amp so there will be 14 of them to add resistors to
a wonderfull sziklai sakis Solid State 203 18th May 2012 11:25 AM
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
Page generated in 0.11590 seconds (79.18% PHP - 20.82% MySQL) with 10 queries
