Fault: No input selection then cuts out.
Remedy: Replace 2 x 100mF caps in power supply module and drive belt on rear input selector panel motor drive. |
#2 |
Hi highviewvideo,
This site doesn't work like you may think. Thanks for the tip, but it may get lost. They way we work is to respond to requests for help and DIY projects. Plus posting your own designs and DIY progress. Welcome to DiyAudio, -Chris
"Just because you can, doesn't mean you should" © my Wife |
#3 |
I guess it was on another site I use that the question was asked and I've posted a reply on the wrong one
![]() Anyway, maybe it will be of use to someone |
#4 | |
Hi highviewvideo,
-Chris
#5 |
I have the same problem. I like to try the solution you describe . Could you please give me some details on how to find those parts in the amplifier (where to search the power supply ..) Maybe you have a picture of it?
thanks in advance, hope to hear. regards Fred |
#6 |
Open the case. Looking down from the top with the front panel away from you the power supply board is in the centre towards the back of the unit. It measures 150x100mm (approx)
On this board are many capacitors but pay attention to two 100mF caps (63V) which may have discoloured. easy to test if you have an ESR meter. Also check for high restsance (dry ) joints. Again looking down at the unit the input sockets are on a board at the near right. You have to remove this board from the unit to gain access to and replace the small drive belt on the input selector and encoder board. I hope this helps. |
#7 |
btw, thanks to google, this site will work exactly the way the poster intended....
#8 |
Thanks, i hope to have some spare time this weekend to check things out!
#9 |
Maybe you have a picture of it? Or help me i have msn whith vidéo
Thank |
#10 |
Sorry but the amp left the workshop ages ago.
The power supply pcb is a horizontal board in centre of chassis. The input selector which has drive belts is directly behind the input sockets. I hope this helps |
| Repair tips for dead Crown XLS602 for newby | timbert | Solid State | 23 | 1st December 2011 12:55 PM |
| Sansui B-2102, huge SS for parts or repair: $75 obo | pjanda1 | Swap Meet | 8 | 20th September 2008 12:03 AM |
| Tips for rebuilding this amp? | Ty_Bower | Tubes / Valves | 24 | 4th April 2007 03:02 AM |
| marshall valvestate 8080 repair tips needed | skid | Instruments and Amps | 4 | 25th April 2006 01:01 PM |
| Page generated in 0.09878 seconds (76.86% PHP - 23.14% MySQL) with 10 queries |
