Old 27th July 2007, 12:52 PM   #1
Default ThermalTrak Bias Circuit
Here's an attempt at posting the zip file containing the schematic of the ThermalTrak bias circuit. The models of the BJTs and diodes used are included. The ThermalTrak BJT models are from Andy_c's improved OnSemi models - thanks Andy!
Bob
Old 27th July 2007, 12:57 PM   #2
Looks like it worked. For convenience, here is the complete post.
This is a ThermalTrak bias circuit that I came up with that I have been working with. It shows a couple of examples of how the ThermalTrak diodes can be used.
The circuit is in the form of a Class-AB 100 watt output stage in simulation form. The circuit is essentially a triple Darlinton “T” circuit that employs two pairs of NJL3281D – NJL1302D OnSemi devices.
Q1-4 just make up a pair of 10 mA current sources that, in combination with the input voltage source, simulate a typical VAS.
Q5-6 and D1-2 make up a feedback-based bias spreader. D1-2 are the key ThermalTrak diodes that work to establish a stable, temperature-tracking bias. The use of the feedback-based bias spreader, as opposed to a conventional Vbe multiplier, eliminates the influence, drift and uncertainty of the pre-driver and driver Vbe’s in establishing the output stage operating point.
Q7-8 and Q9-10 are the pre-drivers and drivers. D5-6 provide a diode drop of voltage offset to make up for the Vbe of Q5-6. D5-6 and Q5-6 are NOT on the heatsink. The relationship of voltage drop for a given current for D5-6 as compared to Q5-6 is involved in setting the bias current.
The voltage drop across R5-6, caused by R7, sets the voltage that will ultimately appear across the emitter resistors R13-16 (albeit modified slightly by some Vbe differences). In practice, R7 would include the bias-setting pot.
The d.c. feedback from the emitters of Q9-10 to the bases of Q5-6 sets the output stage operating point, and forces a tracking relationship between D1-2 and the Vbe’s of the output transistors.
If D1-2 had the same junction drop as Q13-14, and Q5-6 had the same junction drop as D5-6, you can see that the voltage drop across R5-6 would have to equal the voltage drop across R13-14. Corresponding junction drops are at essentially the same temperature. Note that power dissipation, and thus self-heating, in Q5-6 and D5-6 is quite low. This is how the feedback-based bias spreader works. Although in practice the above-mentioned equalities do not hold perfectly, they are close enough, and net differences are made up by trimming R7 to set the idle current.
The two “extra” ThermalTrak diodes, D3-4, are used between the emitters of the driver transistors to establish the idle current of the drivers while keeping the impedance between the emitters very small, so that the drivers can operate in push-pull to provide turn-on and turn-off current to the output transistors. Keeping the impedance between the driver emitters very low at high frequencies is essentially what is often done with the speedup capacitor. The ThermalTrak diodes make it possible to do this in a d.c. fashion with the necessary precision because they track the output transistor Vbe’s.
Bob
Old 27th July 2007, 01:25 PM   #3
pooge is offline pooge  United States
Default Biasing/thermal compensation of Thermak Trak transistors
I'd like to start a new thread to discuss ideas for biasing amplifiers using the inbuilt diodes included in OmSemi's Thermal Trak transitor packages. The simple capacitor in the application note seems a bit simplistic. I was going to use a selected number of these in a diode string in a Vbe multiplier similar to the topology Leach uses so the amp could have the option of using regular transistors and separate diode strings, too, but ideas for
bias schemes strickly for Thermal Traks would also be welcome subject matter.
Leach indicated to me that three diodes were adequate in his scheme, but the forth was added to make the ends of this string come out on the same side of the heat sink. Self believes that intimate contact of the thermal sensor with the transistor could also result in overcompensation, so reducing the tempco may be necessary with the Thermal Traks.
Old 27th July 2007, 01:35 PM   #4
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I have make several tests with the Thermal Track trannies, and it works just fine, even though it seems like the bias became a bit unstable.
I used two NPN and PNP as output devices, and had all four diodes in series plus a 100R trimmer to adjust the bias.
Just build it out of head so no schematic, but output stage had same topologi as the Leach amp
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 27th July 2007, 03:01 PM   #5
Edmond Stuart's Avatar
Hi Bob,
Clever clever design, in particular the "improper" use of D3 and D4. I like that kind of tricks.
BTW: any idea why the sensing diode is so large, IF(AV) = 1A, quite hefty for a sensing device.
Cheers, Edmond.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 27th July 2007, 03:34 PM   #6
Originally posted by estuart
Hi Bob,
Cheers, Edmond.
Thanks, Edmond.
I think the sensing diode is so large (same junction drop as the BJT Vbe at 1/4 the current) so as to make things about right at a typical value of bias current. For example, if the bipolar is biased at 100 mA Class-AB idle current, the junction drop of the thermal diode will be the same at a reasonable current of 25 mA. One could argue, I suppose, that a "reasonable" current might be more like a 10 mA value flowing in the VAS. There is also the possibility that OnSemi was deliberately playing some games with delta-Vbe temperature characteristics of junctions operating at different current densities (as is the practice employed in bandgap voltage references).
Anyway, I was a little surprized at the size as well.
Bob
Old 27th July 2007, 04:04 PM   #7
if one adopts the dual PNP + NPN Vbe multiplier and then inserts two diodes into each collector leg, like a doubled up version of Leach, what is the effective temperature compensation?
Is it the same as a 4diode Leach or is it equivalent to a two diode Leach but with double the voltage difference?
regards Andrew T.
Old 27th July 2007, 04:09 PM   #8
Jan Dupont's Avatar
Just some info
The Voltage drop over the sensing diode is only app. 0.4 V, and the measurements I have done, shows that this is lower than the Vbe for the trannies. Thats why I added a pot in the sensing diode circuit...........
Old 27th July 2007, 04:13 PM   #9
Interesting about the current density vs. diode drop issue. Yet another variable to consider if the current through the diode sensors is supplied from the VAS stage.
Old 27th July 2007, 04:34 PM   #10
Originally posted by ACD
Just some info
Hi Jan,
My measurements of ThermalTrak devices have shown Vbe to be about 610 mV at 100 mA IC, while Vdiode is about 610 mV at 25 mA Id. It sounds like you are measuring the diodes at a much lower current.
On that note, I would also point out that using the ThermalTrak diodes in the base circuit of a Vbe multiplier will typically have them running at a rather low current, perhaps on the order of 1 mA.
If you choose to use a Vbe multiplier, I suggest that you place the ThermalTrak diode(s) in series with the emitter of the Vbe multiplier transistor, inside the Vbe muiltiplier loop. This then means that the effective Vbe of the Vbe multiplier transistor will become Vbe_qm + Vj_D, where qm is the Vbe multiplier transistor and D is the ThermalTrak diode. The majority of the VAS standing current will then pass through the ThermalTrak diode.
Bob
Leach To Thermal Trak zerohead_ak47 Solid State 42 16th June 2011 06:28 AM
new thermal trak transistors sss Solid State 31 27th January 2008 05:40 AM
Page generated in 0.13446 seconds (89.60% PHP - 10.40% MySQL) with 11 queries
