Biasing/thermal compensation of Thermal Trak transistors - Page 2 - diyAudio
Old 27th July 2007, 03:40 PM   #11
pooge is offline pooge  United States
Here's the schematic of Bob's biasing network:
Old 27th July 2007, 03:46 PM   #12
Originally posted by Bob Cordell
Hi Jan,
My measurements of ThermalTrak devices have shown Vbe to be about 610 mV at 100 mA IC, while Vdiode is about 610 mV at 25 mA Id. It sounds like you are measuring the diodes at a much lower current.
On that note, I would also point out that using the ThermalTrak diodes in the base circuit of a Vbe multiplier will typically have them running at a rather low current, perhaps on the order of 1 mA.
If you choose to use a Vbe multiplier, I suggest that you place the ThermalTrak diode(s) in series with the emitter of the Vbe multiplier transistor, inside the Vbe muiltiplier loop. This then means that the effective Vbe of the Vbe multiplier transistor will become Vbe_qm + Vj_D, where qm is the Vbe multiplier transistor and D is the ThermalTrak diode. The majority of the VAS standing current will then pass through the ThermalTrak diode.
Bob
Good idea. Do you have any notion of the capacitance effects of the long traces to the diodes in this scenario?
Old 27th July 2007, 04:02 PM   #13
Originally posted by AndrewT
if one adopts the dual PNP + NPN Vbe multiplier and then inserts two diodes into each collector leg, like a doubled up version of Leach, what is the effective temperature compensation?
Is it the same as a 4diode Leach or is it equivalent to a two diode Leach but with double the voltage difference?
It does sound interesting to use a dual Vbe, one for each positive and negative half. Might allow a cleaner layout for the diode traces back to the Vbe. Depending on the relative asymmetry of the signals, one polarity can potentially heat up more than the other. Self recognized this issue, but only mentioned in passing that the Adcom GFA-565 was the only evidence he had of its commercial practice. I would think that having two bias adjustment pots would be a detriment, so finding a single adjustment for the total bias voltage would be desirable.
Old 27th July 2007, 04:08 PM   #14
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Bob Cordell;
As I said I did it some measurements on a Leach type circuit.....
Can't remember the Vdiode current, but thanks for the info
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 27th July 2007, 04:51 PM   #15
anatech is offline anatech  Canada
anatech's Avatar
Hi Pooge,
I was going to move some posts over here from the seed thread. My connection is very iffy today so I will not risk it.
What you can do, and I recommend this anyway, simply copy the body of the text you what from the other thread and post it here. You could use the copy function to make it clear who posted what before.
Sorry I can't really help today. Not until the connectivity is cleaned up.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 27th July 2007, 04:54 PM   #16
Default ThermalTrak Bias Circuit
I have reposted the circuit description and files here for convenience.
This is a ThermalTrak bias circuit that I came up with that I have been working with. It shows a couple of examples of how the ThermalTrak diodes can be used.
The circuit is in the form of a Class-AB 100 watt output stage in simulation form. The circuit is essentially a triple Darlinton “T” circuit that employs two pairs of NJL3281D – NJL1302D OnSemi devices.
Q1-4 just make up a pair of 10 mA current sources that, in combination with the input voltage source, simulate a typical VAS.
Q5-6 and D1-2 make up a feedback-based bias spreader. D1-2 are the key ThermalTrak diodes that work to establish a stable, temperature-tracking bias. The use of the feedback-based bias spreader, as opposed to a conventional Vbe multiplier, eliminates the influence, drift and uncertainty of the pre-driver and driver Vbe’s in establishing the output stage operating point.
Q7-8 and Q9-10 are the pre-drivers and drivers. D5-6 provide a diode drop of voltage offset to make up for the Vbe of Q5-6. D5-6 and Q5-6 are NOT on the heatsink. The relationship of voltage drop for a given current for D5-6 as compared to Q5-6 is involved in setting the bias current.
The voltage drop across R5-6, caused by R7, sets the voltage that will ultimately appear across the emitter resistors R13-16 (albeit modified slightly by some Vbe differences). In practice, R7 would include the bias-setting pot.
The d.c. feedback from the emitters of Q9-10 to the bases of Q5-6 sets the output stage operating point, and forces a tracking relationship between D1-2 and the Vbe’s of the output transistors.
If D1-2 had the same junction drop as Q13-14, and Q5-6 had the same junction drop as D5-6, you can see that the voltage drop across R5-6 would have to equal the voltage drop across R13-14. Corresponding junction drops are at essentially the same temperature. Note that power dissipation, and thus self-heating, in Q5-6 and D5-6 is quite low. This is how the feedback-based bias spreader works. Although in practice the above-mentioned equalities do not hold perfectly, they are close enough, and net differences are made up by trimming R7 to set the idle current.
The two “extra” ThermalTrak diodes, D3-4, are used between the emitters of the driver transistors to establish the idle current of the drivers while keeping the impedance between the emitters very small, so that the drivers can operate in push-pull to provide turn-on and turn-off current to the output transistors. Keeping the impedance between the driver emitters very low at high frequencies is essentially what is often done with the speedup capacitor. The ThermalTrak diodes make it possible to do this in a d.c. fashion with the necessary precision because they track the output transistor Vbe’s.
Bob
Old 27th July 2007, 05:23 PM   #17
anatech's Avatar
Hi Bob,
Thank you!
-Chris
Old 27th July 2007, 09:07 PM   #18
Default Another ThermalTrak Bias Circuit Variation
The attached circuit is another version of the ThermalTrak bias circuit that I came up with. Some may find this one more attractive. The 1N4001 diodes have been replaced with transistor emitter followers Q11-12 to provide the one-Vbe voltage translation to cancel the Vbe of Q5-6. These emitter followers are powered by stealing one mA from the bias spreader via R10-11. Their collectors are simply returned to the junction of D1-2 to define their collector voltage.
Note that this arrangement buys us one Vbe of additional headroom on each side as compared to the earlier arrangement that employed the 1N4001 diodes.
The second change is the addition of output stage base series resistors R12 and R17 shunted by R18. This combination of resistors causes a slight bias voltage drop of about 20 mV to the output transistors. The purpose of this is to allow the drivers Q9-10 to be biased a bit hotter (now 48 mA) while keeping each output transistor at its desired operating point of 125 mA. Obviously this function can be combined in various ways with base stopper resistors if they are used.
Note that the use of the feedback-based bias spreader is especially advantageous if one is using MOSFET driver transistors at Q9 and Q10, as it will make the bias-setting largely independent of the gate voltage of the drivers.
Bob
Old 27th July 2007, 09:09 PM   #19
Here's the image I forgot.
Sorry!
Bob
Old 29th July 2007, 06:08 AM   #20
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Just inserted a couple of Bob's posts at the beginning of this thread...
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Leach To Thermal Trak zerohead_ak47 Solid State 58 19th February 2015 03:57 PM
new thermal trak transistors sss Solid State 31 27th January 2008 04:40 AM
Copyright ©1999-2017 diyAudio
