Old 1st February 2003, 03:50 PM   #21
jackinnj's Avatar
Application Note 50, Designing Linear Amplifiers Using the IL300 Optocoupler from Vishay
Old 10th August 2008, 08:42 AM   #22
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: HCNR200 - SPICE model data
Originally posted by halojoy
HCNR200 dat in SPICE
so somebody can do some simulations
say, for LF-signals upto 40kHz or so
/halo - does not spice himself - not yet
But I do spice, halojoy
Thanks for your research!
lineup
lineup
Old 10th August 2008, 11:43 AM   #23
maudio is offline maudio  Netherlands
I have built a isolation amp that I often use for measurements when working with high-voltage audio circuits (ESL's and related amps).
It is based upon the hcnr200, basically a modified version of the high-speed lowcost circuit from the Agilent datasheet. Powered by two 9v blocks it makes a very handy standalone tool for this purpose.
But it is rather noisy, I doubt if it will reach 70dB dynamic range. THD at 1kHz is around 0.25%, not spectacular either. When playing music through it you don't need double blind testing to notice that it severely degrades sound. Oh well, the high speed circuit may not be the best in linearity but it will do 750 KHz (-3dB) which is more important for me in this application. Don't know what can be achieved with more refined circuitry.
I did do some experimentation with these devices in high-voltage amps in the past but abandoned the idea after problems with instability and poor linearity. Especially the capacitive coupling is troublesome. 0.5pf may not seem much but the photo diode currents are very tiny and easy to disturb if there is any large AC signal present across the coupler. You will also need separate power supplies for both sides which introduces additional complexity and capacitive coupling.
I don't know what use you have in mind but believe that for most audio applications it's easier to use transformers.
Old 10th August 2008, 12:15 PM   #24
lineup's Avatar
we also have this
Texas Instruments ( Burr-Brown ) application note:
NOISE SOURCES IN APPLICATIONS USING
CAPACITIVE COUPLED ISOLATED AMPLIFIERS
By Bonnie C. Baker (602) 746-7984
http://focus.ti.com/lit/an/sboa028/sboa028.pdf
For the Principal Operation idea of these isolation amplifier chips
see my Attachment.
What I have seen are chips with bandwidth like 50 kHz
.. but there may be considrably faster chips now, with higher resolutions, too
Analog Signal > ADConverter > capacitive barrier > DAConverter > Analog Signal
File Type: png digitalized_signals_capacitive_coupled_1.png (3.7 KB, 311 views)
lineup
Old 10th August 2008, 12:22 PM   #25
lineup's Avatar
Here is a public article (a bit old maybe)
by Burr-Brown workers:
April 2000 - Applications of Signal Isolation
http://archives.sensorsmag.com/artic.../70/main.shtml
regars from Lineup, Sweden
lineup
Old 23rd October 2008, 09:18 AM   #26
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I'm currently trying HCNR200 in an application that requires passing an isolated audio signal to a mains live circuit. The noise floor is barely acceptable. Linearity seems good. Frequency response seems also good.
The big problem is CMRR, the 230V common-mode component does not suffer enough attenuation, it's clearly audible. The problem seems to be input-to-output parasitic capacitance. Could somebody with experience on linear optocouplers provide some hints for CMRR improvement?
I'm considering TIL300 since a CMRR of 130dB at 60Hz is claimed, and a balanced approach involving two optocouplers. Interestingly, HCNR200 datasheet and application notes doesn't provide any data on CMRR.
I use to feel like the small child in The Emperor's New Clothes tale
Old 9th November 2010, 08:12 AM   #27
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
bump
What would be today's options for audio isolation and not with high price tag?
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
FET Switch Isolation using optocouplers instead of conventional gate drivers rtarbell Power Supplies 8 4th February 2011 09:24 PM
another comercial gainclone: audio analogue juluska Chip Amps 11 17th June 2009 12:15 PM
CRO wanted - ie Oscilloscope digital/analogue/signal generator priscared Parts 3 15th October 2008 10:17 AM
Two 7.5 KV (!) Signal Transformer Isolation transformers, only $200, NYC markmaloof Swap Meet 2 12th July 2007 12:47 AM
Audio Analogue Puccini Tyimo Solid State 12 30th November 2006 07:13 PM
Page generated in 0.12197 seconds (71.17% PHP - 28.83% MySQL) with 11 queries
