diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Help me fix this Yamaha YST-SW015 subwoofer (http://www.diyaudio.com/forums/solid-state/105612-help-fix-yamaha-yst-sw015-subwoofer.html)
Nordic 21st July 2007 10:46 AM
2 Attachment(s)
Hi, I took over this sub form a cazy young guy, who brought it to me for repairs a year or so ago... thought I'd keep it, till I'm a bit more handy with these kind of things...
Cause of error.. mains wire connected to car battery, with PSU selector set to 125V range... which needless to say blew the fuses...WHICH HE THEN HARDWIRED...
So far I replaced the opamp on the output which was burned...
On powering up, all the control lights etc, light up... but no sound... which is where I left it... next time I saw the amp, the guys have cut through wires etc, --- too lazy to desolder.. luckily they are colour coded... at which point I took out the speaker, which tested ok, and gave the guy about $20 and took the whole thing...
Now I have learned how to test transistors... I started working my way through the board... and the only dead one I found so far... is in the relay section of the standby circuit.
Not a transistor I can easily find localy...
2SC4688
Datasheet
Can you guys recommend a replacement?
I removed the transformer and it measures nearly 60VAC on the output... do I assume it is damaged, if I look at the numbers on the schematic....?
Nordic 22nd July 2007 11:11 AM
2 Attachment(s)
No help yet?
This board has quite a few dead transistors... and checking the circuit diagram, I have to assume the opamps... and other ICs are also dead...
Here is a replacement I made for the inline ne555 chip, the dual opamp next to it has to receive a replacement too....
I think I will just replace that large transistor with 2sc5200, which exceeds al its power specifications.. seeing that I can't find a replacement... the other dead ones seem to be more traceable, like 2sc2240
Also still in doubt over that transformer.... going to bypass it with a smaller transformer... if it works... I'll know the transformer is damaged too...
Nordic 22nd July 2007 11:16 AM
2 Attachment(s)
For those who like subs... here is a block diagramme of the amp.
jaycee 22nd July 2007 01:12 PM
Transformer sounds like it's ok.
I guess it depends what was toasted to begin with. If he's hardwired it, all bets are off - the whole power amp circuit is probably toasted. You will want to test all parts in that.
Do you have a schematic?
Nordic 22nd July 2007 01:23 PM
Yes I do, but not sure If I can post it... I seem to have a slightly later version than the service manual... and it has the occasionaly incoorectly marked component number... but I think I am getting on top of things....
Luckily the sub has a few relays inside which seemed to have protected the majority of it... It would appear the damage is focused around the auto power on/off circuit, but it did blow the tda7294 on the power amp...
I intend to replace all the opamps, just to be sure...
bridges and diodes seem fine........so far.... still have a board or two to run through....
jaya000 22nd July 2007 04:28 PM
Better post here or somewhere else so that we can suggest u after study.
Nordic 22nd July 2007 05:28 PM
If you are interested, hit the e-mail button below my post, and I will forward the PDF to you... about 2.6mb
Most transistors test ok...
some dead ones are
Q4 - E7 (LOCATION)
Q12 -D2
someone said the transformer looks ok... but 60V is a bit heavy for the 8V reg that sits after this one... there is a main transformer which should put out about 60V P2P
All transistors in power amp, measure fine useing general diode test method...allthough the chip did burn to a crisp... not the same chip im my amp as schematic... but the chip has been replaced, without fixing anything... obviously power will have a hard time getting there with the relay's switching and senseing transistors damaged...
tvi 22nd July 2007 07:09 PM
2 Attachment(s)
The service manual I have says it uses a STK404-070 amp module.
If you want I can email you a copy?
James
Nordic 22nd July 2007 08:07 PM
The unit I have actualy has a TDA7294... as I said, my unit is slightly later version, but same model no...
Nordic 24th July 2007 02:08 PM
At first I thought those sil-8 packages for the opamps were daft, but after assembling a test jig, I can certainly see their use from a layout point of view...
http://img.photobucket.com/albums/v4.../inlinejig.jpg
Replacement opamp tested and inserted into the board shown previously... have to pick up replacement transistors for the dead ones on it tommorrow.
http://img.photobucket.com/albums/v4...s/ystandby.jpg
Resources saved on this page: MySQL 18.75%
