Adcom 555 - Page 3 - diyAudio
Old 23rd July 2007, 04:45 AM   #21
djk is offline djk
djk's Avatar
Look at the current gain above 1A.
Candidates for the Darwin Award should not read this author.
Old 23rd July 2007, 08:12 PM   #22
anatech is offline anatech  Canada
anatech's Avatar
Hi djk,
Hmmmm. I normally use MJE15032 and MJE15033 anyway. I'll have a closer look. There must have been a reason why because I'll typically use the highest voltage part in a series unless something changes.
Thanks for the heads up.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 26th July 2007, 07:51 PM   #23
Send a message via Yahoo to changsecho
Default adcom 555
hi i have to ask this question again i have order the 15032/33 but they have 3 pins coming out of them the ones in the amp have only two what am i missing here the 2dd525 and 2sb595 are no longer available do i just leave the collector pin standing ?????? and use the base and emitter would someone please tell me whats wrong here thank you
Old 26th July 2007, 09:32 PM   #24
djk is offline djk
djk's Avatar
At the rick of repeating myself:
"The metal tab on the TO-220 case is the collector."
Cut off the pin if it offends you.
Old 26th July 2007, 10:01 PM   #25
anatech's Avatar
Hi djk,
My gosh that's funny. Now watch him buy a fullpak!
Hi changsecho,
Firstly, make sure you have purchased the metal tab types. Then, as djk said ...
Cut the center pin off flush with the bottom of the case if you can. If you leave the pin hanging out, it may get bent and short later on.
Those parts you will order are improved substitutes for the originals from a voltage / current perspective.
-Chris
Old 29th July 2007, 06:15 PM   #26
Default adcom 555
hi everyone want to thank you for clearing up that fact on that driver transistor it;s up and runing now sounds great and lots of power i would like to get some output on whether i should change all the transistors in the driver board if so are the transistors made my on are they good ones also would adding on 22uf 100 volts capacitors to the power outputs capacitors give me more bass i;ve seen here on the post where they have added them you all have been much help thank you very much
Old 29th July 2007, 06:32 PM   #27
anatech's Avatar
Hi changsecho,
I will now repeat myself from an earlier post . Okay ?
Firstly, when you post, please use punctuation and caps when required. We are not going to waste time reading your posts a couple times to understand them.
Your posts are difficult to read and it is wasting my time trying to read them. Please have some respect for others that read what you have to say.
Now, how many parts were bad? What were the part numbers?
You don't really get more bass by increasing the filter caps unless you are driving the amplifier hard into a low impedance load. What are the speakers nominal impedance and how many per channel are you using?
-Chris
Old 29th July 2007, 11:15 PM   #28
pchw is offline pchw  United States
I want to add bypass caps to the big 'lytics of my GFA-555. What should be the appropriate bypass caps to use? I searched the previous posts but somehow couldn't find the values other member had experimented.
Thanks!!
- Fred -
Old 29th July 2007, 11:25 PM   #29
anatech's Avatar
Hi Fred,
What most people don't realize is that there are already bypass caps mounted on the output boards. But you can play, just don't make a mess.
-Chris
Old 29th July 2007, 11:37 PM   #30
Thank you, Chris!!
- Fred -
Adcom GFA-565 sourceoneaudio Solid State 11 13th July 2011 01:43 PM
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 04:42 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 11:20 AM
Adcom 2A IC for GFA 565 CompNut Solid State 18 2nd February 2007 07:16 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 09:09 PM
Copyright 1999-2017 diyAudio
