tweeter ( Compression driver) protection circuit
Old 20th January 2012, 08:57 AM   #91
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Protect with halogen lamp
Old 20th January 2012, 09:05 AM   #92
apexaudio's Avatar
This is very good protection with 2N3055, activ at 12V RMS or 34V at peaks on driver.
File Type: jpg APEX HF X-OVER + BJT PROTECT not compress peaks.jpg (139.5 KB, 557 views)
Old 20th January 2012, 09:12 AM   #93
apexaudio's Avatar
For 10W nominal power drivers use 2 X 12V 10W bulbs or 24V 20W single bulb,
2 X 12V 20W bulbs is for protect 20W drivers and
2 X 12V 35W bulbs is for 50W drivers.
Old 20th January 2012, 09:25 AM   #94
R.I.P.
What are the cold resistances of those bulb filaments?
"What if", the bulb filament resistance is higher than the crossover resistor presently in place in the unprotected crossover?
How do we adjust the crossover resistor value/s to account for the bulb filament resistance?
regards Andrew T.
Old 20th February 2012, 12:24 AM   #95
soundboyrich is offline soundboyrich  United States
Explain in as much detail why a parallel fuse is necessary?
The bulb filament resistance is explained over and over in the thread. (I fully follow and understand).
I'm asking myself why bother with the parallel fast blow fuse. During high current (mic squeal or large crescendo), the bulb goes high resistance and the parallel fuse will pass much of the current to the driver. No protection here. Once the fuse blow, the bulb provides protection.
Old 20th February 2012, 09:03 AM   #96
djk is offline djk
R.I.P
djk's Avatar
It's not.
Some would argue that the bulb needs to be bypassed during normal use, and a fuse/polyswitch/relay serves that function.
Candidates for the Darwin Award should not read this author.
Old 30th July 2012, 11:47 PM   #97
Any knowledge on ferrofluid? I've read it helps keep the voice coil cool and typically used on high frequency drivers and tweeters. It's available online as a replacement for drivers with worn fluid. I've read that it should NOT be used on existing non-fluid drivers.
If it increases power handling, what's the typical degradation in response look like? It appears your adding mass to the voice coil thus reducing the highest sparkle of the tweeter sound.
tweeter ( Compression driver) protection circuitHide this!Advertise here!
compression tweeter lizgar Multi-Way 1 19th May 2008 12:55 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
simple super-tweeter protection circuit Macdude443 Multi-Way 3 22nd December 2004 05:16 PM
