Old 18th July 2007, 03:44 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default Preamp PS has too high a voltage- insert R?
Hi, my opamp based preamp has a regulated power supply and draws in the neighborhood of 20mA total (no load, load = ?? have not gotten that far yet...) from the wall. Apparently this is not enough to draw down the 20 VA power transformer, which is 12VCT but creates + and - 20VDC. The problem is that the initial bank of filter caps (4400 uF per side total) feed a pair of Linear Technologies regulators which are spec'd for 20VDC maximum on the input, so I'd really like a little wiggle room to get the input voltage down from 20 VDC to 16 VDC or so.
Inserting a 750 ohm 3 watt resistor (one of those panasonic blue ones left over from a Pass project) in-line with the wall AC at one AC input of the transformer does the trick, reducing the AC from the wall by about 16 V and thus the DC from the filter caps by about 4 volts, dissipating about 0.34 watts as heat.
I would think this also reduces AC noise by the same proportion, a good thing. The LT regulators now get 16 VDC and output about 12VDC which makes them very happy.
Any problem with doing this?
My DIY audio projects- PartTimeProjects.com.
Old 18th July 2007, 03:52 PM   #2
you could also try the LM7815 / LM7915 1.5 amp voltage regulators from national, the input to this regulator needs to be between 17.5 VDC and 30 VDC which sounds like right in your area. I am not sure if putting a resistor in series with the line voltage is the best idea, but i will leave that up to someone else to answer who has a bit more mains voltage knowledge then me.
Dave
Old 18th July 2007, 04:20 PM   #3
lgreen's Avatar
Dave
Right, those would work but I've already designed, ordered and stuffed my own PCB for these particular ultra low noise surface mount LT 1962/1964 regulators and it works great.
I could add in a 2nd "pre" regulation stage to feed the LT regulators but the problem with that is that (1) it would add noise using lower performance regulators, and (2) I would be compelled to use 15V fixed TO-3 regulators because the chassis is already cut for them and it would look super-cool.
I guess the issue with adding a resistor is the impedance of the AC line goes way up, but not sure if this is a real world problem given the tiny power requirements and relatively large filter caps.
Other than the 4400 uF per rail previously mentioned, each opamp has a pair of local 22uF caps right next to it and the regulators themselves feed a 220 uF cap on their output.
Old 18th July 2007, 08:20 PM   #4
you could split your filter bank and use an RCRC supply.
Adjust the Rs to get the highest voltage you can tolerate at the lowest output current and highest mains supply voltage.
You could also add a Zener or shunt regulator after the first and/or last R to pull the voltage down.
I do not like your idea of fiddling with the mains side.
Seems like an accident waiting to happen.
regards Andrew T.
Old 18th July 2007, 09:09 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi lgreen,
I agree with Andrew, I'm not too fond of resistors on the mains side. What would be nice is a series resistance on each DC rail. This would be followed by a capacitor, giving you a C-R-C design. This allows you to use your low noise regs and enhances the high frequency attenuation from your supply (a good thing). Use the most inductive resistors you can lay your hands on!
Reducing the input capacitance would also be a good thing. Do you know how short a conduction angle you must have now?? That's RFI central. Some ripple would be preferable in the first stage because your second stage will smooth it out and your regulators will have an easier time with that then the high frequency bursts from your original design.
What do you think?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 18th July 2007, 09:58 PM   #6
lgreen's Avatar
Ok guys, I got the idea of using the R's in-line with the AC from the Pass Labs Pearl Phono that I just finished. See attachement, it uses a 4.7 ohmer in each AC leg, and I'm just using one and making it bigger, no?
I'm not worried about saftey as it is well insulated from prying fingers.
Come to think of it, I forgot that the regulator board has a set of 1000 uF caps on the front end input so it would be easy to mod this thing for a CRC supply to feed the regulator. I'd use C=4400 (bridge board) R = 200 and C=1000 (reg board). This should give me a drop of about 4 volts at 20 mA load.
Anyway, thanks for mentioning the conduction angle and the RF, I am a little worried about the RF , i'm gonna have a lookie see and check it out. Appreciate the comments and you spending time on my posts.
other comments appreciated...
Old 18th July 2007, 10:45 PM   #7
ilimzn is offline ilimzn  Croatia
If you have several filter caps in parallel, modifying the supply for a RCRC (note R at the start!) is a good idea, assuming there is always some load curren (say, a LED indicator...), to produce a voltage drop. The R at the beginning (before first cap) will widen the conduction angle and also smothen the ripple current, leading to a rather drastic reduction in RFI, at next to no cost.
You could also insert a diode string or even a low voltage zener in series with either supply, but honestly, I'd consider this a crutch. If it was me, I'd probably be winding anti-series windings on the transformer, before I'd go putting diodes or zeners in series...
If everytihing else fails, you have another possibility - put a cap in series with the transformer primary. Essentially, it's a non-ohmic voltage drop, but this technique is generally OK only for approximately constant current demand, and also, it needs to be additionally snubbered to prevent resonance with the transformer inductances (so, in practsie, a scope is required). Considering you have a relatively small conduction angle rectifier on the secondary, the current waveform is bound to hit the resonance(s) with one/some of it's harmonic/s so a snubber resistor (or better) is a necessity.
BTW a resistor in the primary side (assuming you are carefull to make it touch-safe) is not that unusual, and in fact looks like a correspondingly reduced resistance from the secondary side. The bonus is that it lowers inrush current at power on, and also acts as that first 'R' in the RCRC I mentioned above, so increases the conduction angle. It is even possible to use it as part of a filter by putting a series R-C across the transformer secondary - in essence, you make a Zobel network to compensate for the primary resistor and leakage inductance of the transformer. It helps greatly with diode switching transients, but needs measuring and/or modeling to get right.
Old 19th July 2007, 12:13 AM   #8
anatech's Avatar
Hi lgreen,
That's silly overkill and a complete waste. If you reduce this to 1,000 uF (2,200 uF max) you will have a cleaner supply.
I agree with ilimzn (see my sig line though). I'd prefer a much more controllable R as a drop also in your secondary. The R-C-R-C is one of my favorites as you take the edge off the charging current. Your caps run cooler and so would your transformer.
-Chris
Old 19th July 2007, 04:09 PM   #9
lgreen's Avatar
oh there's gonna be some LEDs, let me assure you of that!
Thanks for the explanation you guys know your stuff! I tried a CRC and it works just fine with a 47 ohm power resistor, drops 2.8 volts. May try a RCRC with two 20's to see how that works.
Old 19th July 2007, 09:05 PM   #10
anatech's Avatar
Hi lgreen,
Cool! Great news. Now you will have a low noise supply as long as you get the grounding right.
-Chris
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
High DC offset voltage at preamp output mmerig Solid State 18 23rd May 2008 07:44 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Regulate the high voltage making better sound? (Preamp) 9999 Tubes / Valves 20 20th January 2005 05:21 PM
High voltage OPAMP / PREAMP hugeli60 Solid State 7 17th February 2002 08:03 PM
Page generated in 0.12627 seconds (84.38% PHP - 15.62% MySQL) with 11 queries
