#51 |
The attached image should help to understand the differential circuit modifications for improving soundstage, as described in my previous post.Different amplifiers may require different methods.
If anybody wants a larger copy, please email me. Sandyk |
#52 |
diyAudio Moderator Emeritus
Hi, SandyK,
Between those 3 methods, all using the same indicator (adjust for 0.0mV)? |
#53 |
Lumanauw
Yes, assuming that the differential pair is closely matched for HFE and VBE, try to adjust to <5mV difference between their collectors when warm.Only use minor adjustment of the VAS emitter resistor so as to not affect it's correct operation. If unable to achieve with only a small variation of the VAS emitter resistor . try the diode and resistor method instead. Using the 2 series diode method, you may be able to get closer by selecting a suitable 1N4148, as their forward voltage does vary a little between diodes. BTW, it is adviseable to use matched 1% resistors in the emitters of the differential pair and current mirror. The actual measured value of these 1% resistors isn't as important as them being close in value. SandyK |
#54 |
SandyK,
any possibility you could email me the orogonal Silicon chip article, or point to where I could find it? |
#55 |
Bonsai
Silicon Chip now has a brand new 20W Class A which does not need an external PSU. If you like to email me, I will give you further information. SandyK |
| Suitable capacitor types for Cdom | Shaun | Digital Source | 6 | 21st October 2007 04:40 PM |
| An unusual VAS CDOM variation ideas from a web page | gaetan8888 | Solid State | 0 | 12th October 2007 07:43 PM |
| Any reason to add CDom? | TomasF | Solid State | 2 | 11th May 2007 02:55 PM |
| Placement of compensation capacitor | rtarbell | Solid State | 8 | 20th February 2006 12:33 AM |
| cascode compensation? | mikek | Solid State | 4 | 10th October 2004 11:14 PM |
