Here's a 20 watt amp, very simple but sound good
Old 17th July 2007, 10:11 PM   #1
gaetan8888 is offline gaetan8888  Canada
Default Here's a 20 watt amp, very simple but sound good
Hello
Here's a 20 watt amp, very simple but sound good, for those who want a small power amp, it's from Fairchild Semiconductor, 1974
Here's the shematic;
For the output darlington transistor you can use 2N6388 and 2N6668 , made by On Semiconductor, cost arround $1. at Mouser.com
I did made one for a friend, few years ago, it was sound very good.
Here's what I did get on my HP333 distortion analyser.
Distortion vs frequency
1khz .07 %
10khz .08 %
20khz .1 %
30khz .12 %
Distortion vs power output at 1 khz
.5 watt .17 %
1.5 watt .12 %
4 watt .05 %
12 watt .16 %
17 watt .5 %
20 watt 4 %
Try it and say your listening impressions.
Gaetan
Old 17th July 2007, 11:23 PM   #2
GK is offline GK  Australia
The SAP devices by Sanken would work well here too.
Datasheet:
http://www.farnell.com/datasheets/82862.pdf
Glen
Old 24th September 2007, 10:28 PM   #3
Kapibara is offline Kapibara
Look very nice.
I will testing soon.
Old 24th September 2007, 11:30 PM   #4
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Hi
Without emitter resistors in the darlingtons , I'm afraid the quiescent current is not stable , and thermal runway can occur ...
Jorge
Jorge
Old 25th September 2007, 01:05 AM   #5
Originally posted by Tube_Dude
Hi
Jorge
No. In that design the darlingtions are biased cut-off (ie < ClassB), so emitter resistors are not required, as there is no quiescent current.
It would generate heaps of crossover distortion.
That's why I mentioned the Sanken parts..........
Glen
Old 25th September 2007, 05:16 AM   #6
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Probably worth increasing the bootstrap cap to 100-220 uF, 50v - should improve the bass response below 30 Hz. Also a small bypass cap - say 1-22 uF, around the diode/resistor Vbe bias chain should improve the highs.
A small miller capacitance of around 33-100pF between the base and collector of Q1 should help suppress AC instability.
I've built something similar to this, but with a Vbe multiplier for crossover biasing, bias stabilization resistors of 0.2R in the emitters of Q2 & Q3, and 2N6054/59 TO-3 output darlingtons.
Old 25th September 2007, 02:57 PM   #7
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
AHhhhhh!Output coupling cap!
Old 25th September 2007, 03:41 PM   #8
robo7 is offline robo7
AH, a modern design...
was popular almost 40 years ago.
Old 25th September 2007, 05:24 PM   #9
This amplifier is class B or class AB ?
Old 25th September 2007, 06:05 PM   #10
Dzsoni is offline Dzsoni  Hungary
It's only a bad joke now in 2007...
Here's a 20 watt amp, very simple but sound goodHide this!Advertise here!
What makes the good guitar pickup sound so good? darkfenriz Instruments and Amps 15 1st March 2009 11:46 PM
10 watt Simple Power Amp danville Solid State 16 29th June 2008 02:15 AM
Any good flea-watt SET designs? Rocky Tubes / Valves 68 15th May 2004 10:37 AM
Copyright ©1999-2017 diyAudio
